Hi guys,I am looking at a buying a V36 coupe.
I originally wanted an auto as the manuals are alot more expensive in the same condition. However I have come across one in VIC that is dirt cheap and I have had it inspected by my mechanic aswell who has given me the go ahead.
Before I buy it, I just want to know if there are any issues or things that are good to know about the 6 speed models. I couldn't find much info so I thought I would ask.
https://www.sau.com.au/forums/topic/421999-v36-issuesadvice/
I don't think there are any particular issues.. the weak synchro issue was resolved during the V35 run, so won't be an issue on the V36.
Take it for a test drive and see what you think.. the feel of the V35 6MT took a while to get used to, even for experienced manual drivers.
Cheap, fast, reliable. Pick two.
When you say cheap, it depends on what you mean. There is a big difference between a car being sold for $5k under market for a quick sale and $20k under market because its f**d.
In regards to the boxes, haven't heard any issues. Just look after it.
In relation to title, a little more thought next time. The guys can offer a wealth of info when you ate clear and concise with your request.
All the best. Hope you find an awesome car!
It's not that cheap, its about 5-6k under market value. The guy is trading it in, showed me receipts for the new car he purchased. Everything is legit, Just wants to make a few bucks on top of the trade in value.
Well thanks for all your help guys.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
