Hi guys,I am looking at a buying a V36 coupe.
I originally wanted an auto as the manuals are alot more expensive in the same condition. However I have come across one in VIC that is dirt cheap and I have had it inspected by my mechanic aswell who has given me the go ahead.
Before I buy it, I just want to know if there are any issues or things that are good to know about the 6 speed models. I couldn't find much info so I thought I would ask.
https://www.sau.com.au/forums/topic/421999-v36-issuesadvice/
I don't think there are any particular issues.. the weak synchro issue was resolved during the V35 run, so won't be an issue on the V36.
Take it for a test drive and see what you think.. the feel of the V35 6MT took a while to get used to, even for experienced manual drivers.
Cheap, fast, reliable. Pick two.
When you say cheap, it depends on what you mean. There is a big difference between a car being sold for $5k under market for a quick sale and $20k under market because its f**d.
In regards to the boxes, haven't heard any issues. Just look after it.
In relation to title, a little more thought next time. The guys can offer a wealth of info when you ate clear and concise with your request.
All the best. Hope you find an awesome car!
It's not that cheap, its about 5-6k under market value. The guy is trading it in, showed me receipts for the new car he purchased. Everything is legit, Just wants to make a few bucks on top of the trade in value.
Well thanks for all your help guys.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
