Didn't know it was available outside of Nismo JP, traders in Japan won't send, or if they do they require a min. 6x 1L purchase.
The LSD is supposed to come with 2x 1L Nismo LSD oil, but they don't seem to supply it with the oil outside of Japan.
Will chase it up locally, to see if I can get it, thanks.
I was aware of the generic Motul version, however I'm led to believe they are not 100% the same.
I assuming Nismo has a specific blend of friction modifiers etc to suit the LSD for an OEM feel i.e. minimal chatter.
I used the Castrol to good effect.
Add some Penrite friction modifier if you get too much chatter
Thanks, might end up being easier to source.
  • Replies 52
Yes the Nismo stuff although also made by Motul is a higher spec. In NZ Motul is available through a number of parts shops and the Nismo version is also available from Nissan dealers.
This appears to be the Aussie distributor - the website lists stockists:
http://www.linkauto.com.au/index_page.html
Unsurprisingly no listed stockists in WA.
On further research it's apparently the OEM fluid on later model R35 LSDs (and recommended on earlier), so I have no doubt I'll get my hands on it one way or another.
  • 1 month later...
LOL turns out Motul is changing it's Australian distributor.
Both the current & future Australian distributors are dream boats that decided to jerk me & the retailer sourcing it around, and decided that it's all to hard to do their job.
I buy the Nismo stuff from Nissan. Since its specified for the GTR you should be able to get it from your nearest Nissan dealer as well.
Tried that, Nissan (over here anyway) doesn't stock/carry it and referred me to the Motul local dealer, to which there are none in my state.
I can buy it from a US Nissan dealer over ebay, but I'll get stung 50% of the price in freight.
I've settled for Just Jap who seem to have it on hand (waiting for confirmation), however I'm getting stung a bit in freight and higher item costs so I'll be $50 worse off :(
LOL @ swear filter, I'll let you guess what dream boat means
If you scroll down this listing you will find the diff oil for NZ$58 a litre - what prices have you had so far? I will email my contact @ Cockram Nissan to get an up to date price.
http://www.trademe.co.nz/motors/car-parts-accessories/oil-additives/auction-608121833.htm
Too hard as it can't be air freighted, but that's significantly cheaper than all prices I've come across.
Decided to go with regular Motul comp fluid, as it's far easy & cheaper to get my hands on, and others I've spoken to have been happy with it's performance.
If it doesn't work out I'll try something else at the service interval.
Thanks for the help.
  • 1 year later...
Reviving an old thread. The consensus seems to be the Quafie front center is the overall favourite.
Although we haven't had any input from anyone using either of the 2 Cusco front diff options:
the RS model: http://www.rhdjapan.com/cusco-type-rs-lsd-diff-front-nissan-bnr32-bcnr33-bnr34.html
the MZ model: http://www.rhdjapan.com/cusco-type-mz-lsd-front-limited-slip-differential-r32-r33-r34-gt-r.html
If anyone has one of these or knows somebody with one could you please weigh in? the Quafie unit's are a fair bit more expensive from Just Jap ($700 more) and I only just sent and email to Piggaz's contact - Thanks for the contact btw Paul
My engine is out and it is not going back in with a stock front diff! Help me make a decision please! I would love a helical from Quaife but I don't think I can justify the extra $$ for it. Thanks
Quaife is a known winner, just read a few threads here to understand.
Im currently fitting a RS Cusco 1 way in ours, front diff casing needed some grinding to creat enough clearance to slip it in as its wider where the clutch pack body is.
Do it while the sump is off so you can clean the alloy shavings out easily.
Type Cusco RS centers are suppose to run a 80w140 oil in the rear and lighter 80w90 oil for front diffs.
In my case im using a Motul Gear competition full synthetic 75w140 for the front diff due to power loadings on the gears.
For Cusco RS centers the oil must contain a friction modifier.....
Edited by GTRPSI
Sounds like a bit of a headache. Is your car far away from being finished? I'd love some feedback on how it drives once it's all sorted
Bottom end done, headwork half way there.
Fitting a LSD is not a headache, its just a bit of grinding to clearance so the unit can fit in.
Even removing the stock one is a bit of a tight fit, aftermarket ones having a larger body need some more room to slip in.
Edited by GTRPSI
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
    • Why would you not fit the biggest possible brakes?
