Hi guys,
got a r34 GT-T NEO, checked my coolant this morning and it is dark brown. there was a little bit of sludge on the bottom of the radiator cap and i put my finger in the coolant to find really small traces of oil.
from my experience when the head gasket is blown the coolant is a lot worse, but I'm not a mechanic. i have checked a lot of other forums but can't get any specific info that matches up to my issue.
i have had the car for 6 months and there has been no problems with cooling system it always sits just under half.
Not sure if the following information will be valid but over the weekend i took off the stock turbo and put a high flowed VL turbo, i used my old waste gate and bolted it to 2 plates that were bolted to the side of the compressor housing, i assumed the plates were flexing because it wasn't boosting very well. i then changed the plates to something a bit more sturdy and took it for a drive, on my old turbo i was running 12 psi and when i tested this new turbo it boosted to 17 psi i then straight away turned the boost down to 8 psi. could this have caused me to blow the head gasket when it over boosted?
https://www.sau.com.au/forums/topic/422012-head-gasket-blown/
Wouldn't think 17 psi would kill it, what was condition if turbo when u got it? Did u hook oil and water lines up correctly? Doesn't sound good but if your not using water or oil get a good radiator flush and then refill with coolant. If it comes back you need to go to radiator shop and get it co2 tested its really all you can do other than guess.
Scott
had you checked the coolant in the past?
is your oil milky coloured?
does the car blow steam (like plumes of white smoke) at first start up?
17psi from a hiflow turbo on a non tuned motor can cause problems but not really a BHG.
If it were me I would:
Dump the coolant, flush the radiator out with a hose.
remove the thermostat and flush out as much of the coolant/water out of the engine by sticking the hose in there..
dump the coolant/water in the overflow tank.
and if real keen, I'd undo the massive bolt under the turbo on the engine block which is to drain the remaing water/coolant from the engine.
Change the engine oil and oil filter - Use cheap oil here cause you're only doing it to clean it out if it's all milky and will dump it aftre like 2 drives.
Put it all back together, fill it all up with demineralised water, bleed the system, drive around without thrashing...for half an hour keeping an eye on the temp gauge.
let it cool and check the radiator again... if it is dirty or has lost water, then you probably have a blown gasket.
what you do from here can cost between $15 to whatever it costs to pull the head off, have it resurfaced, new head gasket, put it all back together etc etc.
When I bought me Neo it was all very very nice......except for the cooling circuit. It took 2 months and 8 changes and 2 muchout treatments to get it to clean up.
If this is the first time you've looked in your radiator, the coolant could have been full of rusty grunge the whole time. Some people simply have no idea about looking after that sort of thing. You may have inherited it.
Is this an auto trans? If so, the auto trans cooler/heat exchanger inside the radiator may have split. Check the auto trans fluid inside the trans for traces of water too (just incase). If it has split, you have 2 options: replacement radiator, or block off the stock trans cooler outlets by linking with a piece of hose and run an external cooler instead.
You can buy bottles of cooling system oil remover (500ml from memory) which you add to the cooling system to break down the oil and flush it away. Works really well!
If none of this applies to you, please disregard :)
Oil isn't milky jut a bit murky and very small traces of oil, no steam or white smoke.
I only hit full boost once but it sounded ok.
I have checked the coolant every now and again because of summer but when i changed the turbo we lost a lot of coolant, after i filled it it was ok but i checked after 2 days of driving and filled it up again and thats when i noticed it was dark brown.
Na its a manual.
Hope this is enough info for your queries.
Thanks for all the suggestions i will definitely try them out.
i really don't want to change the head gasket just looks like so much work to get everything off, i had a hard enough time trying to make this other turbo fit.
Please, if you have any more advice or queries on this topic please post it, as i have one more question.
sorry to go off topic but there was 1 other problem that came with the turbo swap, after i stretch a gear i sometimes pop it to neutral to decide what gear i will select next, which all depends on the traffic situation. sometimes the engine has enough time during this process to go back to idle which was fine before i changed the turbo i would just rev match and select a gear, now only after i stretch a gear it will go lower than idle and turn off, not sure why???
before i changed the turbo, when the engine was warmed up it would idle at 1000rpm now if it decides to idle and not stall it idles just under 800.
Any ideas ???
Also just wanted to say that i love this forum and you guys are so helpful and honest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
