Yes.
Apparently ended up in internal disciplinary action for the driver, as it was not his first time.
He cut me off, drastically, so that I had to take evasive action. After I beeped, he then flipped me off and continued to do so up until I pulled over and attempted to gain entry to the bus. He mellowed out after that
Didn't get touched.
Did you get hit?
My old housemate got rear ended, with the driver just driving off.
Ended up going through his insurance, but driver disputed it, claiming my housemate pulled into his lane, reducing his stopping distance
I didn't get hit. Stopped pretty close though. Thank gawd for ebc pads! The backs feel like they have flat spots and I'm also getting a lot of vibration from both rear wheels. Might give the insurer the heads up.
Edit: could be in for rotors and rubber if this resulted in some damage. Am also picking up some noise from the wheel bearings. It's too wet to go and check right now but will ASAP.
similar thing happen to me... had to brake hard a swerve.
beeped, got the finger.
took photo on the plates and note of location.
reported it via email.
got a call the next day. complained more and informed them I'll go to the media.
Bitch got fired.
suck shit kunt!
Edited by TTT
lol... You braked hard to avoid an impact (as brakes are designed for) and now something is wrong and you think they should fix it?
lol... You got no chance mate.
sounds like your car was not road worthy if shit is broken from braking hard.
lol. It was 60 down to 0 very quickly,. All I'm saying is something isn't right. They've fixed wheels and tyres before when it;s been their fault. Shall hear back next week and go from there.
If you hit a pothole and damaged a rim, I could understand that council may be liable (stretch but still maybe).
If you are driving along doing 60 and a grandma in a hybrid camry pulls out of her parking spot without looking and you jump on the brakes and do a little ABS skiddie and don't have an accident, but later you feel that the rear brakes are a bit weird, is it her fault?
I can't see how someone you "almost" had an accident with could be liable for something on your car failing when used as intended.
Just means that the now faulty part was not road worthy.
If you give first gear a push and hit the limiter, then the next day you find an oil leak, are you calling up Nissan?
i had a bus pull out of a bus stop and nearly take me out one day. i know you are supposed to give way to them etc, but he didn't put the indicator on until i had just passed the back corner of the bus and then just pulled out straight away.
talking to a mate who used to be a bus driver, or work in the management side of things (can't remember which), he said that drivers are supposed to wait something like 4 seconds after they put the indicator on before they even attempt to pull out. on the other hand though, he also said that with the new LED indicators on a lot of buses these days, they can take up to a few seconds to start to flash after the driver puts the indicator on. so that just screws everything up.
I'm glad to hear no one got hurt.
Happens on the Goldie as well. Every time I see a bus at a bus stop I try immediately to merge into the other (right) lane if there is one as IMO they don't give a sh!t about you.
Yes, I understand they have a schedule to run and considering roadworks, school zones, etc... they are always under pressure to meet that schedule hence, why they are pressed for to make up time but at what costs?
HOWEVER.....just because we need to give way to them doesn't mean that they have to be arrogant and abuse it and more importantly tag innocent motorists because of that.
I'm certain its been brought up many times before with translink, Qld transport and other authorities, but bottom line is that justice does not prevail. In addition to that the public transport is already bad as it is
What they fail to realise is that if there is a severe prang resulting from such a situation NO ONE is better off as the bus will be reported in an accident, the passengers may be injured, the bus gets nowhere, passengers get nowhere, the car will be totaled and the driver will be mangled, and bus driver will be let off with slap on the wrist.
Its really about time theses bus drivers start thinking a bit more about safety of the passengers and other motorist instead of just a f@#king timetable which already late anyways.
There I feel better and I hope you do too.
Edited by Ants
To the people that said t they got the driver fired or disciplinary action taken against them. Do you actually have any proof of this happening other than a letter saying action has been taken?
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
