Just wondering if 2750 has the most Maccas of any Postcode? Ever counted?
I know Krispy Creme did a lot of research into the best location for their first store(high percentage of fatteh's); hence it's appearance in the 'Riff.
So us fatties also have Golden Arches at
*Kendall St
*Mulgoa Rd
*Penrith Plaza
*Old Bathurst Rd
*Castlereagh Rd
...all in 2750
...not including Werrington, Cambridge Gdns or Glenmore Pk
SHAME,Shame on us!!! Lol
lol youve got the one outside panthers, the high street, westfields and the new one on peach tree rd. Then youve got emu plains, 2 in stmarys, 1 in st claire... so much delicious heart disease in the area!
dont forget the one in Cambridge gardens ;)
St Clair Represent :) probably driven past or herd you go past my house a few times. Next time you drive in saddington st st marys when you slow down for the spped hump at the school just give her a little boost. Ill see it from my balcony haha.
  • 3 weeks later...
Cops just chased someone into my building > entered the office next door > then mine > we went down the hallway.
Found him hiding in a cubicle.
Welcome to Penrith!
Maybe this is a new job seeking technique?
"Nah mate; I has been werkin' here for aaaaages..."
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
