hey
pick up would be best im in logan QLD well post at buyers cost
need all sold ASAP if you need any more info or pic let me know and ill do my best
Call or txt me on 0403 763 014
Apexi AVC-R boost controller type R $270neg
Greddy turbo full auto timer $40
Apline CDE-9873E with ipod cable $120neg
Apline type R 6 splits set$100
(in 300zx trip well remove before sending)
Blaupunkt TH Series with tweeters (no box) set$50neg
Alpine Vpwer mono MRP-M352 $60neg
200w/350w 700w max
Phoenix gold tantrum 500 2 channel $60neg
125w/250w 500w max
still to come 12" MTX sub in box and genuine nismo steel gear knob
300ZX (Z32) PARTS
all parts taken out of a 1990 2seat 5 speed twin trubo
All are neg
Center console ash tray $100
Center console $100
Cluster 123,838Km $100
ECU $90
Air con and washer control $70
Light controls $70
Turn signal switch $20
Cluster surrounding $50
Power window door switch left and right $30
dome light $30
Wheel boss cover not sure what its called $15
Dash cluster cover leather $40
still to come OEM passenger seat
Edited by madman_rocks
Light controls $70
dome light $30
Need sold ASAP
12" MTX 250W 4 ohm sub in box $100neg
genuine nismo stainless steel gear knob $40neg
used little ware next to writing and little on the top on the side rest is fine
300ZX OEM passenger seat $50neg
sorry about the no photos
ment to have photo but it wont let me upload
if you would like a look ill send you an email or something
i well keep trying
Need sold ASAP
i well keep trying
Auto-meter water temp pro-comp ultra-lite $50neg
from 100 to 250 F the back was moded to have a bigger light but works fine well be selling with sender, drift gauge holder and led light
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
