here is the other issue i am having. like i said i did a full conversion taking all the r32 mechanical parts and using it on the a31, the diff has also been changed to the lsd one that came with the r32. like others have stated the 1st half of the driveshaft is the same (with out the second half it would bolt sraight up as there is lots of room to pull it back to get the bolts to line up). the second half i needed to get adjusted so i got a machinist to cut and swap the end that bolts on to the first half. he said he maintained the same length and he balanced it. but when i bolted it up i needed to actually pull the center bracket back about 1/4 inch to line up the holes on the holes on the body of the car (not the whole drive shaft as i had little or no room room to move it. as you know the center bracket is made up of a rubber piece (not sure of the correct name) this is where the movement came from for me to get the bracket to move back 1/4 inch). now i have two questions linked to this. from this it looks like the 2nd half of the shaft is 1/4 inch to long or is this how it usually is? does anyone know the length of the second shaft from end to end. i am getting a slight vibration (not all the time) i don't know if he did not balance the shaft properly or if it has to do with the center bracket being pulled back 1/4 inch to get the holes lined up. would this cause any damage or the vibration. appreciate the help
https://www.sau.com.au/forums/topic/422049-a31-driveshaft/
I don't fully understand what you have done here, but I have done this conversion many times, never had any issues with the "hanger bearing" is the name your looking for, and it has always been a bolt up job, even with a R32 LSD
R32 front shaft onto the a31's rear shaft, early cefiro's need the flange swapped, easy once you have undone the big tight ass nut, not the case with series 2/3
once thats done there should be no issues with fitment,
take some pics for us, hopefully may be able to see whats up
if the shaft is vibrating, take it out of the g/box turn it 180 the slide it back in, had to do this with mine, problem went away
https://www.sau.com.au/forums/topic/422049-a31-driveshaft/#findComment-6791214
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
