As the title suggests , doing a manual conversion on an RS4 , 33 ECU and wiring - 2WD with gearbox .
The Turbo is getting old so i thought with the build a new Turbo would be an idea . Now it will be a manual I am thinking a larger/unrated turbo would be beneficial .
I would like to stay with original T3/4 fixings but if that is not a good idea tell me !
Any experience and issues would be a great help .
Head over to the Hypergear turbo thread in the forced induction section; Stao is pulling some pretty impressive numbers with bolt on highflows.
His current one ran 350kw (I think) admittedly E85 on a fabricated manifold, but it looks like a stock r33 turbo.
Getting your old turbo beeefed up has the advantage that it will just bolt straight in. If you have the time you cold post it to Hypergear or there must be local rebuilders although as above Stao from Hypergear has done some great development work. If you want a brand new turbo the Garrett GT3076 could get you 300kw if done right.
I use the garret 3076r 56t with a .63 on mine with a manual awesome turbo and not to much stuffing around to make it fit in my terms , makes 338rwkw on 17psi so more to come yet when I turn the boost up (that's using e85)
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
