Car has been sitting there for 4 months start it up. Slight knocking noise
Dump the oil change the filter add some lifter stuff as that was first thought a stuck lifter.
Still same noise but louder
Here's the list of things we checked
Water pump- took belt of so it wasn't spinning
Spark- took spark plugs out and turned it by hand
Coil- unplugged the coils one by one. Still there
Turned it over by hand.
Cam covers off. Took off, spun by hand then started it without the cam covers, no issue
Injectors - took injectors off, unplugged one by one sound still there
Also removed cam covers and ran the car. Knock is definitely lower down then cams
My knock
Video that covinved me
So, anyone have any ideas ?
https://www.sau.com.au/forums/topic/422052-rb25-knock/
It doesn't sound like a spun bearing to me. More like lifter noise. Probably since the car has been sitting for so long the lifters are gummed up and there isn't the right amount of oil in the hydraulic lifters. You can take them out, take them appart and clean them then re assemble with some oil in them. there is a thread on here in the DIY section of how to do it.
https://www.sau.com.au/forums/topic/422052-rb25-knock/#findComment-6791128
I reckon he stated man that lifter stuff has been added, Death rattles for me have always sounded alot worse than that to me. While it doesnt sound very healthy and could possibilly be a spun bearing i would check these things
1. check compression, should be all even and around 150psi
2. It sort of sounded like a leaking exhaust manifold gasket from the video so maybe check that
3. If its got fresh oil and the lifters are the problem try driving around gently and see if the problem perists, if it gets better chances are it was just lifters :)
https://www.sau.com.au/forums/topic/422052-rb25-knock/#findComment-6792144
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
