Congrats to squizz finally cracked 12s.. (bloody SMS woke me up :usuck: )
Known mods:
HKS panel filter
My old exhaust (2 x 2.5" frontpipe to 3" catback)
removed boost restrictor
previous owner had the car lowered
12.7@106mph 1.8s 60ft
https://www.sau.com.au/forums/topic/42206-squizzs-gtr-is-into-12s/
don't they do that stock? :)
i think you need these...
Been trying to sell these for a while on this forum have gone from $1800-$1500.
now i am lookign to have them gone for $1000 FIRM, cost me $2500 a year ago, and all they have done was sit in a box in the cuboard.
They are off a 1996 GTR V-spec that had around 45000km's. they are in excellent condition and come with dump pipes, O2 sensors, and manifolds. Ideal to twin turbo a VL, all that is needed is an adaptor plate as all of the exhaust ports match up.
I am short of money at the moment and the first person in with the money will get them. I don't want to be ****ed around, let me know and i'll get you my bank details asap, and send them off...
direct deposit only, $20 freight to anywhere and i'll pay thre rest. will be sent with registered/insured post.
Regards Nathan
p.s. will get pics up asap.
Congrats to Jay and Neil.
Had to leave early as I promised the missus I would be home by lunch.
Thanks for the invite Neil :)
I will have that cooler piping sorted by the end of the week and then hopefully do a full 1/4 mile :)
nothign quite beats the sight of a cooler pipe running its own 400m :D
damn hose clamps :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
