Z32 Afm With Plug / Sard 650Cc Topfeed Injector's (1001-87094) / No Nameplate Airesearch Turbocharger(Gt3071 ? / Td04 ?)
Genuine JECS Z32 afm, mesh in excellent condition, sensor looks untouched. pick up or will post at buyers expense. msg me on $200
0403718653
650cc topfeed Helix ? or PE injectors, came out of friends rb20, flow tested all ok $500
AiResearch Turbo, twin scroll,v-band
the only specs i can give are from the castings $600,
. A/R .70 (exhaust housing)
. GIL 4 (compressor housing)
. M27 (compressor housing)
. R.S.M 8 (shaft housing flange)
. M3 (exhaust housing)
There is a M8 diameter hole in the rear housing near the manifold flange for some reason ? might of had a temp probe perhaps ?
R32 GTS-T Part's
. Stock suspension - $120
. Stock Air-Box - $120
. Rear Wing - $50
located glen waverley vic
Edited by hirsty
  • 3 weeks later...
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
