Hi guys just finishing my build and I took the sump off to look at the inside it has eagle rods and when I pulled the caps and checked clearance with plast gauge it's about 2 thou but the bearing all have a consistent blueing colour to them where the mains don't, is this normal or should I replace them? Crank journals are perfect.
Scott
https://www.sau.com.au/forums/topic/422064-big-end-bearing-colour/
Can you post a pic mate?
Please also give us some history on the motor and what brand the bearings are. Tell us where you bought it, who built it and how many KM's its done.
Cheers,
I can't post pic from phone, bought from another member, 2000kms built by john milentis in Gold Coast , ran penrite running in oil for 1000ks then another penrite semi synthetic I think, r34 crank brand new std oil pump eagle rods cp pistons, jun sump baffle, tomei oil restrictor and external oil drain, it's just colour no pick up and crank perfect. Cam Jounals perfect also.
I think the lack of punctuation is creating that confusion. I'm gonna guess its a second hand r34 crank, but new std oil pump.
The blue staining is std on acl bearings. They all tend to have it, just some have more then others.
Gee if your referring to my punctuation sorry but I'm recovering from brain surgery and regardless this is a mechanical forum not an English lesson. I'm not sure if crank was new or not but oil pump certainly was. Judging people without knowing their circumstance is cruel and silly at best.
I never said it wasn't good enough. I don't care for the use of proper English or not. But the way the engine parts were listed could have made it slightly confusing for others.
So back on topic, I have had acl bearings with almost no blueing on them and some with lots. I think it's apart of the coating on them.
It was trozzle to whom I was referring, I ordered another set from uas, as for $100 it's just not worth the risk due to the work involved it putting these engines in and out. I thought it may be ok though as they are all the same from 1 to 6. Thanks for the constructive feedback guys.
Scott
Be it myself I would pull the crank and give that to a machinist, let them check it and then give it back to you with a matched set of bearings. Shouldnt cost any more than $400.
That's a much safer way to go.
Also, Trozzle wasnt being mean to you mate. He was being sarcastic to the person who whinged about your grammar. He also said your post was fine.
Dont worry, you will get the help you need. Sorry to hear about your surgery and hope everything ends up fine.
Scott
What the other Scott said.
Personally I would remove the plugs and turn it on its head. Then disassemble all the bottom end and leave the pistons/rods in it. Take the crank off and all, clean up the mess you made and put it back together as your own.
Is there any reason you don't want to take the balancer off? Surely its not balanced all the way through when they are only using eagle rods?
The only thing id be worried about is if the rods are out of round. Its going to be next to impossible to check while they are attached to the motor coz you wont be able to torque them down or possibly even fit the tool in. The journals being the cause of added heat is 1 concern but the actual closing of the rods another. You can only do whats feasible though and theres no point rebuilding an entire bloody motor purchased because it was already built, it defeats the purpose.
Too late to refund due to concerns?
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
