Ecu Clean Out Z32, R32 (Rb20 & Rb26)
Description: Nissan ecu's 3 x z32, 5 x r32 rb20 1 is a mines ecu 1 is a impul ecu, 2x rb26 fitted with Nistune boards will also suit R33 and R34 GTR
We can also fit a Nistune board for an extra cost to suit rb20 or rb25 heads. (Extra $370 fitted)
Contact: PM or 0438804282
Price:
R32 Rb26 with Nistune $550 each
Z32 $250 each
R32 RB20 $230 each
Pickup available postage extra
  • Like 1
  • 1 month later...
  • 4 weeks later...
  • 3 weeks later...
  • 6 months later...
  • 1 month later...
 Share
    • Oooohhh man did not bloody know that, that's amazing thanks heaps for sharing mate, bookmarked it!
    • In case you haven't come across it, there's also https://nissan.epc-data.com/ Go by VIN or drill down into your specific model and year and it'll have references for pretty much all the OEM parts. In very similar diagrams. Linked against amayama as well for ordering. Though they can be a bit slow and can be better to search around to get the parts locally.
    • Just in case anyone finds this in the future, here's a diagram sent to me by Nissan to identify these hoses. I ended up finding them through EFI Solutions though because Nissan reckons they need to order it from Japan, with a total cost of approx $110 inc. So it as cheaper with EFI anyway. https://www.efisolutions.com.au/blow-by-hose-rb25det-r33-wc34-c34-c35 https://www.efisolutions.com.au/blow-by-rocker-cover-hose-rb25-r33-wc34-c34-c35
    • This is an older post of mine but I just thought I should update it and explain what the problem was. Long story short the friction plates were below their service limit. New they are around 4mm, and service limit is (according to OSG) 3.5mm In addition the crank seal gasket wasn't sealing 100% anymore and that led to an oily clutch. Not sure what came first and why the clutch was worn after just 10,000km .. but all good now. OSG refresh kit via Nengun
    • My r34 GTT auto transmission is slowly letting go, slipping every now and again, tiptronic deciding to not keep it in 1st / 2nd when flooring it, taking longer to shift so I’m going going flush it and replace the filter and hope it lasts a bit longer.    I’ve got 10L of Penrite ATF FS at home and I’m going to use it for it unless ye completely recommend against it.  Penrite list it as compatible. i understand I should be using Castro Transzmax however it’s quite expensive and I already have 10L of the ATF fs. Has anyone here used atf fs for there got or heard of anyone? Or am I silly for even considering anything other then Castrol  Thanks for your advice
