Lol it looks like you did a skid with your pushbike x2 :P
Haha just got it on my phone :yes: nice one!
Of course that is a private road? Your driveway i assume?
Yep bigger tires... They're needed.
Have some videos, absoloute waste of time going down with those tires. As Noel (#Fineline) put it "I've seen better grip from an iceskater".
Ended up going 13.9 @ 104mph, that was baking first and second then getting off the throttle and onto the brakes then back on the throttle.
Like I said waste of time, ill go back with a set of racing tires and aim for some decent numbers.
Much MUCH better times to come, watch this space ;)
Unfortunately at 7pm last night a dog ran infront of my car. I've just gotten home and assessed the damage an thankfull it is all cosmetic with causialties including my grill, number plate, head lights, indicators and cracks in the front bar :(
Have already sourced some new headlights indicators and rear shocks (not related to the incident) to fix the problems :)
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
    • If it's been tuned idle rpm can be changed.
    • Very slightly as there are bars connecting both sides of the ramp. The only difficulty that I had was doing the gearbox, everything else so far has been ok
