.... 13.7 for a relatively stock ls1 in a reasonably heavy car is pretty good going. Your 33 is about the same weight as a commo with no interior or fat chicks. Most people have no idea how fast a flat 13 sec 1/4 really is.
N20 time... :yes:
I do. And this car should be getting close to them IF Nick setups the rear suspension AND tyres.
I'm in a heavier car, running 13.004 down the quarter at 106MPH.
Nick ran originally 13.9@106MPH in a car that is way lighter than I am.
Probably a smaller torque converter would help get this thing off the line easily, OR really really sticky rubber. Chasing more power is not going to help if you are already struggling to put power down at the half way mark...
I have et slicks sitting there, I never dropped my tire pressures the other day and I'm on stiff coil overs :)
I want a 12 second street car... It's just a matter of time
This is true... but for 2nd run at the drags with a poor set up it's not too bad.
As for improvements... Better tires, 0 static rear camber, softer rear springs/shocks, re-angle the rear cradle, adjust ride height to straighten drive shafts, lighten the car more, VHT tire prep.... list goes on. How far do you compromise???
No need to lighten it, it just needs a sensible suspension setup put in it.
Softer rear shocks and springs, get rid of the epic camber, and run low 13s.
PS: My 13.004 was on my first EVER run at the drags... ;)
But Pineapples, different shocks/springs, realign suspension, DONE. Go run flat 13s on same power.
  • 1 month later...
Not really an update but a bit of car activity:
Dropped the oil and changed the oil filter and air filter yesterday preparing the car the the little run it got a Queensland raceway with the supra club yesterday. Overall the day was good with some mighty fast supras there, an even a 1uz powered jza80 (which I actually chopped down the main straight ;) )
So yeah just a few shots from the day.
Big thanks to QLDSC in particular tara and scott i know how much effort goes into organising events like this aswell as SAU Qld, Mike, Tony, Scot, Boz etc fantastic to see the club moving forward and getting back into some driving orientated events :)
Cheers
Cheers
vids of you chopping v8 supra
Waiting for boz to finish editing the video, it was closeish actually but this definetly had more grunt must say the thing sounded sexy as sin was basically straight piped
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
    • Welcome.  Here's what I have noticed about forum vs FB..... FB; seems to be wallet racing, and the same few questions asked over and over. There *may* be some groups that are closer knit, but most have changed for the worse. SAU; unfortunately, no longer in its glory days. But....genuine people with similar interests. Not all about how much you spent and saying you dont have enough power. Sooooooo much knowledge available. Have personally seen people post up about literally topics I made myself, asking on FB like no one has done it before. Most has been done, and most of that is here.   If you ever feel like just general chatting theres the wasteland.  Other interests are also generally covered in other areas of the forum. Hope you enjoy hanging around. We would love to have you.   P.s. nice 32 😀
