Your engine is still basically a standard LS1 with a mafless tune and exhaust isn't it?
It's got a fairly big cam in it (and associated valve train gear) but she's still on stock heads and bottom end :) (makes just under 270rwkw). Being on the little 235 street tires there wasn't a lot of grip, was leaving from basically idle trying not to get it to spin, would of loved to of had a set of et streets on it and see what it could really do but just didn't have the spare cash sitting there :(.
Here's another for comparison lol
yer that run against you was terrible man red light, turned tire on the change to second and threw it into forth too early, your Gtr had me nervous lol.
So as a lot of you know I've wanted MR 33s (#SCR48) rear drag wing set up for a while now and over the weekend it came up for sale and I ended up finally getting my hands on it :)
Just went for a little run up and down the highway, new setup gets lots of attention but so far it's all been the good kind (not the blue and red flashing lights kind :) )
  • Like 1
  • 2 months later...
it actually looks good
  • 9 months later...
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
    • I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
