So ghey. Needs more 1JZ foo!
See you Sundy big guy. :wub:
How about an sr20 cortina ;)
But yes definitely keen for Sunday, I should fix this exhaust leak but don't want up fark anything up before then.
i fitted my front camber arms yesterday and wound a bit of neg into it (moreso for looks lol)
Also had it out for qr happy laps today, and it went well for being what is essentially a stock motor. My battery clamp broke so I couldn't corner to hard also cooked my pissy Natro brakes and my rears tires are now catus :thumbsup:
*note shit house front fitment as my 30mm bolt ons rub to much, so I took them off and will purchase a set of 20mm
The car looked like it went well man! Whats next on the menu?
Yer I was really happy with it, went really well for a stock motor. Next on menu in no particular order:
New tires
New brake pads
New front wheel studs and spacers
TO FIX THIS BLOODY GEARBOX!
New tires
New brake pads
stoopid question.... your gbox prob and tacho probs.... they couldnt be related could they? speed sensor issues etc?
just a thought honky!
His speed and tacho probs are just that the signal going to the gauges is wrong.
The correct signal is getting to the ECU which is doing shifts. The ECU has identified a fault with Soln A in the box, and hence locked it out.
didnt know it was confirmed as solenoidssss. thought he had checked em.
    • Because the drive dog for the steeering angle sensor is present on wheels that came in HICAS cars and not present on wheels that came on non-HICAS cars. Not that I would let that bother me, because HICAS is trash and any excuse to get rid of it is a good excuse.
    • My plan is to replace both Shift Solenoids A and B, and good idea on the Torque Convertor Solenoid as well.
    • I mean, I am always taking donations for a newer model!!  If you'd like to sponsor me. I would gladly get something else!! LOL
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
