Hi Guys,
i have a R33 skyline rb25DET Manual coupe
Just had a question regarding my brakes. is a little bit of a noob question :P aha
basically i will be driving along and just say i slightly put my foot on the brake to slow down coming up to a set of traffic lights if i down shift a gear to slow down as well while my foot is still on the brake the pedal depresses down further. They seem to be a little spongy and not as touchy as they used to be. I have noticed that if you are just idling and press the brake pedal repeatedly a couple of times it takes a couple of pushes till you cant push anymore also the revs go up and down slightly while you do this .
What do you think it is ?
Brakes just need a good bleed ?
Master cylinder gone ??
or brake booster ??
Thanks
https://www.sau.com.au/forums/topic/422094-r33-brakes/
it would be to do with the brake booster as it has a vaccum feed from the engine. the higher the vaccum, the more power it has.
as for pumping the brakes, pretty sure that's normal as you are just pumping up the pressure in the system. and i have a feeling that the brakes in my commodore do a similar thing as yours do when pushing the clutch in, etc, when the vaccum changes (such as turning on the aircon, etc, since it's an auto)
https://www.sau.com.au/forums/topic/422094-r33-brakes/#findComment-6792306
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
