Mallanats April 6Th & 7Th 2013
sky30
 Share
you wouldnt see as much as alma compared to the nats and alot more thing blowing up and dying, Kila B, gary myers, BLOWN and a few other very tough cars are now confirmed, love watching the variety and some crazy sleeper conversions, 500rwkw 6ltr turbo.....sigma
Hey all,
Will be entering my R33 GTR and also my 355 stroker yellow torana with yellow interior! Cant miss it!
I went to the last one just to watch, expecting to not like it. Was expecting Bogans, jap haters etc etc BUT i found it to be really good.
Most people there were very well behaved, marshells were friendly but wouldnt tolorate wankers.
very well run and things to see 24 hours a day!
Definatly worth the drive to have a watch!!
http://www.mallala.com/events/mallanats/
Car Clubs
Cruise to Mallala with your club or your mates and we’ll organise an area for you to park together…and put your club cars on display! Old school, new Jap..whatever…bring it along.
Find our ‘Clubs Special Offer’ below, which has discount tickets for clubs. Note: Offer only applies for genuine clubs and clubs must park together.
MallaNats Car Club Offer Here
hmmmm?
I ended up goin in it, but my alternator failed lunch time sat.
I agree with your comment, and there was way too many cars, cruise the track was just putting around at 30kmh.
Ah damn mate thats no good...
Totally agree, way to many cars, WAY to many dickheads doing burnouts on cruise the track to have a decent drive. And most events are aimed at the V8s. I just cant get into the whole burnout pad event!
Not sure if ill enter the GTR again but will take the torana in again
  • 10 months later...
It wasn't to jap friendly till I won the drags and go to whoa . They all came around in the end but . Im hoping me and my brother v8 turbo sigma see it out together for a laugh. And ill be running slicks not sliding all four first and second . post-103277-13938130649304_thumb.jpgpost-103277-1393813122367_thumb.jpg
 Share
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
