Hey everyone I bought a skyline r33 gtst 1996. So the guy told me it had a r34 turbo a front mount and an exhaust I told my mate to have a look at it and he said its also got a Mitsubishi bov. Do I get an after market bov or a stock one ? And also who do I take the car to, to get the boost up to at least 10psi ??
https://www.sau.com.au/forums/topic/422114-new-guy-with-a-skyline-r33-gtst/
on a stock ECU, yes - you get breakups after 11 or so and a massive rich-and-retard in the middle (i know alllllll about this one :( )
even with aftermarket ECU, try to stay at 13 or under - reliability and all that, the turbo's almost 20 years old if still stock.
Hmm - you can probably run 12psi then, but yeah, with stock ecu you'll get massive rich-and-retard in the middle (like it has MASSIVE lag in the middle of the RPM curve), then comes on ridiculously strong. If you're not used to it, you'll punch your car into a pole.
If you haven't had a turbo car before, set it to 9psi, have a play with that, and then once you're confident (and I'm still assuming no funny business on the roads), then look at moving it upwards.
When I first got my 33, mine was set to 12psi and it scared the living shit out of me. (admittedly with a Power FC so the midrange grunt was back)
Lol umm well I'm kinda getting used to it that's why I've been asking just started a little funny business on the road and haven't had problems. Maybe I should leave it at 10psi and see what happens from there.
There is no way of saying what boost to set the car to to avoid R&R. Mine used to R&R at 8PSi. Why? Because I had an efficient intake and exhaust.
The ECU goes spastic at a certain AFM voltage depending on RPM. AFM voltage is all about air flow, (Cubic feet per minute for example of air flow). Boost pressure is all about a restriction.
Restrict the exhaust, and then at the same boost pressure you'll make less power. Why? Less Cubic Feet Per Minute of air flow.
For the sake of your turbo, set the boost below 10PSi.
For performance sake. Set the boost on a dyno, and still keep it below 10PSi.
Haha I don't think I'm ready for track still getting the hang of it.
I had my mate drive it and he showed me its full potential so when I learn to drive like him then ill take it out on track.
The track is the best place to learn how to drive it, and it's the only place you want to drive it hard.
Take it out to a Texikhana too, very good for learning your driving skills.
Yep, definitely Texi - helps you learn heaps more about how the car handles and reacts - nice and cheap too!
The next step from there's doing a Marulan Driver Training Centre day, awesome fun. You go in the learner group, and take your time. Did that last time and learned heaps about how the car flows on the track, first time out on a real track.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
