New Guy With A Skyline R33 Gtst !
Youii
 Share
Hey everyone I bought a skyline r33 gtst 1996. So the guy told me it had a r34 turbo a front mount and an exhaust I told my mate to have a look at it and he said its also got a Mitsubishi bov. Do I get an after market bov or a stock one ? And also who do I take the car to, to get the boost up to at least 10psi ??
on a stock ECU, yes - you get breakups after 11 or so and a massive rich-and-retard in the middle (i know alllllll about this one :( )
even with aftermarket ECU, try to stay at 13 or under - reliability and all that, the turbo's almost 20 years old if still stock.
Hmm - you can probably run 12psi then, but yeah, with stock ecu you'll get massive rich-and-retard in the middle (like it has MASSIVE lag in the middle of the RPM curve), then comes on ridiculously strong. If you're not used to it, you'll punch your car into a pole.
If you haven't had a turbo car before, set it to 9psi, have a play with that, and then once you're confident (and I'm still assuming no funny business on the roads), then look at moving it upwards.
When I first got my 33, mine was set to 12psi and it scared the living shit out of me. (admittedly with a Power FC so the midrange grunt was back)
Lol umm well I'm kinda getting used to it that's why I've been asking just started a little funny business on the road and haven't had problems. Maybe I should leave it at 10psi and see what happens from there.
There is no way of saying what boost to set the car to to avoid R&R. Mine used to R&R at 8PSi. Why? Because I had an efficient intake and exhaust.
The ECU goes spastic at a certain AFM voltage depending on RPM. AFM voltage is all about air flow, (Cubic feet per minute for example of air flow). Boost pressure is all about a restriction.
Restrict the exhaust, and then at the same boost pressure you'll make less power. Why? Less Cubic Feet Per Minute of air flow.
For the sake of your turbo, set the boost below 10PSi.
For performance sake. Set the boost on a dyno, and still keep it below 10PSi.
Haha I don't think I'm ready for track still getting the hang of it.
I had my mate drive it and he showed me its full potential so when I learn to drive like him then ill take it out on track.
The track is the best place to learn how to drive it, and it's the only place you want to drive it hard.
Take it out to a Texikhana too, very good for learning your driving skills.
Yep, definitely Texi - helps you learn heaps more about how the car handles and reacts - nice and cheap too!
The next step from there's doing a Marulan Driver Training Centre day, awesome fun. You go in the learner group, and take your time. Did that last time and learned heaps about how the car flows on the track, first time out on a real track.
 Share
    • You guys are amazingly knowledgeable and I appreciate it all so much. I’m currently at the local RB tuning shop, getting her inspected and diagnosed, for the t-case debacle and everything else. I’ll keep you guys posted!
    • Like @Dose Pipe Sutututu mentioned, 10W30 on a built motor would not be a great idea. As for the steel wool, we think alike as I went ahead and put SS wool into my catch can as per my above posts.
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
