ddrallystagea Posted March 22, 2013 Share Posted March 22, 2013 Hi all My stock M35 decided to run like lumpy porridge for my fiancé on the highway to canberra yesterday. It got us home but is clearly unwell. I can still hear turbo noise under acceleration in the normal spots, but it has no grunt and idles really rough. Also for the last few weeks it's been developing a bit of a flat spot between 3.5-4k. Thoughts? From reading other similar posts I'm thinking afm, hoping it's not the turbo... No engine light and it starts and runs, just badly. Do they typically spit hoses? Any suggestions would be great! Cheers Andrew Link to comment https://www.sau.com.au/forums/topic/422161-m35-spat-the-dummy/ Share on other sites More sharing options...
joshm35 Posted March 22, 2013 Share Posted March 22, 2013 try cleaning the afm Link to comment https://www.sau.com.au/forums/topic/422161-m35-spat-the-dummy/#findComment-6792106 Share on other sites More sharing options...
scotty nm35 Posted March 22, 2013 Share Posted March 22, 2013 You should be able to check all the basics yourself, check all the vac lines are on, look for loose hose clamps, make sure the intake is tight and the afm is plugged in properly. The stock hoses are fairly robust and don't normally split. There is a good chance the turbo threw a few blades unfortunately, is it louder than usual? Link to comment https://www.sau.com.au/forums/topic/422161-m35-spat-the-dummy/#findComment-6792216 Share on other sites More sharing options...
Equilibrise Posted March 22, 2013 Share Posted March 22, 2013 I would say either a hose or pipe on induction side has come off, or afm requires cleaning or replacement. I've had both happen recently at different times. Also, some of the guys on here have gotten new afm off amayana.com (i think thats what it is called) and I would recommend this over nissan. Nissan charges $309 retail!!! Link to comment https://www.sau.com.au/forums/topic/422161-m35-spat-the-dummy/#findComment-6792218 Share on other sites More sharing options...
ddrallystagea Posted March 22, 2013 Author Share Posted March 22, 2013 Thanks guys. Afm out to be cleaned in the morning, hoses look ok, although there's plenty of them so I may have missed something. Turbo doesn't seem louder than normal, so I'm keeping my fingers crossed! Will update as I go... Link to comment https://www.sau.com.au/forums/topic/422161-m35-spat-the-dummy/#findComment-6792471 Share on other sites More sharing options...
ddrallystagea Posted March 27, 2013 Author Share Posted March 27, 2013 Hi all Cheap success! The turbo's fine! Old plugs had caused a couple of coil packs to pack it in. All fixed, purring like a big fat kitten again. Thanks for your suggestions. Andrew Link to comment https://www.sau.com.au/forums/topic/422161-m35-spat-the-dummy/#findComment-6796561 Share on other sites More sharing options...
vi3t Posted March 28, 2013 Share Posted March 28, 2013 Sounds like same provlem im having how did u diagnose which coil pack it was? Link to comment https://www.sau.com.au/forums/topic/422161-m35-spat-the-dummy/#findComment-6797953 Share on other sites More sharing options...
ddrallystagea Posted March 30, 2013 Author Share Posted March 30, 2013 Bought 6 beers for my mechanic mate... I'll ask him and let you know. Link to comment https://www.sau.com.au/forums/topic/422161-m35-spat-the-dummy/#findComment-6799226 Share on other sites More sharing options...
