Hey guys,
Had plans for my car but my car got stolen a few weeks ago which has forced me to sell the parts. So basically, my loss is your gain! All these parts are brand new never fitted and need to go!
1. Brand New HyperGear ATR43SS2 Internally-gated Turbocharger W/ Braided Oil Line Feed (not pictured)
This is a turbo that was built by Tao at HyperGear which is rated good for 280RWKW with supporting mods. This turbo bolts straight into factory manifold and lines, so straight and simple installation. Comes with a braided oil line feed which isn't pictured. I'm looking for $1400 O.N.O
2. DeatschWerks 740CC Side-Feed Injectors
Brand new set of 6 x Deatschwerks Injectors for RB25DET. This bolt straight into injector rail without any modifications or collars. These are rated at 740CC, which provides plenty of juice! Perfect for E85 setup. I'm looking for $700 O.N.O
3. Bosch 040 In-Tank Fuel Pump
Brand new Bosch fuel pump. Pretty straight forward. I'm looking for $170 O.N.O
4. HICAS Lock Bar
Brand new HICAS lock bar. I'm looking for $50
All these parts have never been fitted and are all brand new parts. I'm located in coburg/thomastown. Prefer these parts to be picked-up as I have no time to organize shipment. Please call 0423 734 102 for all inquiries.
Cheers,
Laz
  • 3 weeks later...
  • 1 year later...
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
