Hi all,
Need to get my car tuned in the next few weeks so need some money. Am selling the following parts. More will be added when I get a chance to go through it all.
Item 1: Apexi AVCR Blue Screen Electronic Boost Controller.
These things are awesome. Only selling due to sticking with a boost tee for now and will go for something else later. This has all sensors and wiring to plug it in. $300
Apexi AVCR by Peter Mackellin, on Flickr
Item 2: Nissan Cefiro A31 RB20DET ECU, Engine Loom and Coilpack Loom
Bought this but is not needed for my car. Selling for just $230 for the lot. Just want to get rid of it. Not cut and is boxed up as delivered so ready to go immediately.
Contact: Reply, PM or SMS/Call 0424 144 fivetwofive
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
