1996 Nissan Skyline S2
Alot of money has gone into this car. Work and tune has been done by JEM. It has made 300kw plus at the wheels and has more in it still. The interior is in mint condition as is the exterior.
Some mods
r34 neo engine with 175psi compression on all 6.
Tomei cam gear.
Tomei poncams and valve springs with retainers.
N1 oil and water pump.
Garrett gt3582 turbo with external waste gate.
Hks exhaust manifold.
Full exhaust system.
18inch custom painted black starcorp rims.
Custom airbox.
550cc sard injectors.
Apexi Fc with hand controller.
Apexi boost controller.
G4 adjustable coilovers. height and dampening
Greddy blow off valve.
Bigger fuel pump. not sure what it is though.
Twin plate clutch.
Greddy style plenum.
Intercooler.
Splitfire coils.
320km white face cluster.
Double din clarion dvd screen with sony split and rear speaker hooked up to an amp. Sounds great.
Side skirts, painted white already just not on the car and stock wheels.
Plus more things i just cant remember.
$15000 or swap for something of interest. Money either way.
0406769404
https://www.sau.com.au/forums/topic/422197-r33-s2-300kw/
  • 1 month later...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
