Stagea 260Rs Rb26Dett Idle Issue
GGGTS4
 Share
Hey my fellow SAU'ers
I am having an IDLE problem with my Stagea 260RS S1 that has RB26DETT on it.
The idle goes up and down and not stable between 1500rpm down to 200rpm and sometimes stalls especially when called.
We have checked the AAC valve.. and cleaned it aswell.
I have read somewhere that TPS can be another issues and need to check the voltage, I have a datascan but I dunno what values i should be looking at.
We have tried swapping Air Flow Meters with my mates RB26 R34 which doesnt have any idle issue and plug it in to my Rb26 and it still doing the same behaviour.
But what myself and my mate notice is, when we pull out the plug out of the water temp sensor that goes to the ECU and the idle started to be stable around 800-1000rpm range.. But ones plug back in.. the idle goes up and down again.
We have tried swapping the water temp sensor with the R34 one, idle still the same, going up and down.. but we notice the part number is different on this RB26 water temp sensor compare to mine.
Is there anyone can give me information and point me to the right direction what else should I test and check?
Would be much appreciated!!
Cheers Sau'ers
  • 4 months later...
 Share
    • Think I found another reason to buy the Q50 rather than the skyline import, seems that unless you get the 400r the other models such as the GT miss out on the decent brakes and don't have the flappy paddles on the steering wheel to change gears. Its my day off work today and the Q50 listed @ the dealer in Brisbane that I mentioned in my 1st post looks like it sold as its listed as no longer available... Would have checked it out but can understand why it sold as it was a bargain price.
    • omfg.... That shopping list game. I'd hoped I'd never see it again.
    • There are fixes for this. In industry we use compressed air for everything. It is frequently wet, and many things cannot tolerate it. So there are various forms of driers available that you can install. The simplest option for something like this would be a dessicant drier. Much cheaper to replace some silica gel than actuator cylinders.
    • That's a solid update mate, well done at WA FOS. You may already know this, but the actuators on the paddle shift are a service item and are sadly not that reliable. As I understand it they collect water from the compressor (condensation) which then rusts the bores/pistons in the actuators. A mate of mine had no end of trouble with them in one if his circuit cars, apparently it's a 'known issue'. Buy a couple of spares at great expense to ensure you never have any problems with the ones you've got! Any clues about what the new WTAC rules might be? While faster cars are cool the Pro class arms race has got to the point where you wouldn't even bother entering without a $1m budget and even then I don't think you'd win.
    • https://nissan.epc-data.com/skyline/er34/3945-rb25det/trans/317/31940N/ The pictures of the part you're talking about is clearly not just one solenoid. You can see another picture of it here: https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/RE5R01A/product/9305/ The 4 speed automatic in the GTT is Nissan corporate stuff. You can search up similar jobs done on a Frontier or Pathfinder with a RE4R01B to get an idea for what the internals are going to look like and the procedure like this:
