My R33 Gtst is hitting Hi boost every time I step on it hard. And I mean straight away!
I have no boost controller yet.
It's stock exept a Apexi Pod Filter, Turbo back exhuast.
This is what the car like before I declared it's troubling!
The car will be at 5psi boost from 1000 to 4000RPM then goes to 8psi boost.
This happens during the whole 3rd and 4th gear, when the foot is lay down!
NOW, the foot lays down, 1 sec of turbo lag and the rest is at about 8psi boost and drops back alittle and on it again. The revs go from 2000 to instantly 4000rpm and down to 3000 and go normally up...
I thought it was the wheel spinning, but nope, not that!
I resetted ECU, yes, it helped for a day!
I resetted it because there was a leaking hose to the boost gauge, was like that for a week till I got it fixed. so i think the ecu has learned it self a wrong setting of the car. reset done now.
What is happening? is my O2 sensor broken? ecu farking up? or boost valve gone?
help!!! thanks people!
https://www.sau.com.au/forums/topic/42225-boost-problem/
That sounds to me like your clutch is slipping.. ((The revs go from 2000 to instantly 4000rpm and down to 3000 and go normally up))...It slips making it rev high faster then it grabs forcing the engine to loose revs....
Yep it sounds like a clutch to me.but what you said about the computer, i dont think it would be right.The reason being you computer doesnt controll the revs of your car your foot does.Think about it what else can controll the revs with such ease and take them away..Maybe your actuator no i dont think so though??I dont know if a sensor would do that!i doubt it.But it sounds like the behavior of a worn clutch.How long have you had the car for?
good luckske's....
https://www.sau.com.au/forums/topic/42225-boost-problem/#findComment-863764
i seriously don't know how long the clutch has been with the car! I got the car a bit over 8 months now! my mechanic once said the clucth when new should grab when release the foot for a little bit. mine is like have to release like 80%! is that another sign of a worn clutch! fark, I have to falk another $500 out? any one know places with cheap clutch!
https://www.sau.com.au/forums/topic/42225-boost-problem/#findComment-863794
Yea theyre ''self do-able'' a 2 person job.But i would only be doing it with someone who has done this sort of thing b4.Seen one seen them all.Or if you never have,pay someone to do it for you.The only hard part about it for me was tilting the engine to gain access to top bolt then.Box down and box up to slide the spline back in.
https://www.sau.com.au/forums/topic/42225-boost-problem/#findComment-863842
man, that's cheap! every where is selling for $550 or more
where did you hunt that down? please let me know!
Matins clutch and brake U3,13 blaxland rd,campbelltown 2560 Tel:02 46281177.
i had to take the old one to swap over though otherwise i would have had to pay $550 to buy it outright.
https://www.sau.com.au/forums/topic/42225-boost-problem/#findComment-863909
LOW25T: I don't know how to! LOL, and if I do, how would I tell the differnce! Every time I try to do a stand still burn out, my car just rocket forward! LOL...
Trust33: Thanks for the info, very very useful! but do they do the swap over as in they have a workshop there or they are just stock exchange warehouse.
https://www.sau.com.au/forums/topic/42225-boost-problem/#findComment-863937
I was under the impression that there is a stock solenoid which regulated the boost in such a way that the boost will display characteristics as you mentioned holding at 5 psi for a while then jumps to 7-8psi later.
The revs are probably your clutch slipping though. Rb25det gearboxes are apparently really heavy, might not be a good idea to do yourself unless you got a hoist. My friends have had HD organic Exedy clutches installed for $800ish.
https://www.sau.com.au/forums/topic/42225-boost-problem/#findComment-864496
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
