How To Get Rid Of This Sticky Crap That Has Stayed Behind After Removing Black Side Strip ?!
I peeled the black rubber strips down the side of my r33 gts4 off the other day, i baked the car in the morning sun and peeled them off. One side came off just like a sticker and didnt leave anything behind. The other side i think may of been reglued on or something at some stage and has left this sticky shit behind?! Tried soaking it with WD40 and soaking it in the sun it is a little bit easier but still so stuck on there. Wondering if anyone has some you beaut way of removing it?!
Any help will be greatly appreciated,
Cheers !
Hair dryer and you can old credit card or plastic knife...but honestly its often easier with your fingers unforunately..clean with turps ,prepsol,wax and grease remover or maybe bug and tar remover..but dont scrub at it or it will.scratch
ITs a pain in the ass that stuff I know, it wither comes off clean or doesn't come off. My work used to put stickers all over my truck and it was the same deal :/
Got it all off ! I got a supercheap club plus card and sharpened an edge on the concrete and soaked the crap out of the sticky stuff with 5.56 which is just a cheap WD40. It came off so easy took me 5 minutes to do the whole side of the car when earlier it took me a good 15 mins just to do the tiny but on the front quarter, and didnt mark the paint at all! Would recommend doing this to anyone that gives it a go i was suprised at how easy it came off ! There are still a few tiny specs but i think they should come off with a good polish !
thanks for your help ARTZ, was having a mind blank didnt even think to use a plastic card !
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
