I suspect, for the money, you'd be far better off simply cleaning up the factory manifold than going the Brae side mount. The Brae one gives you all the bad things of not being factory (like defectability, having to move and change stuff) and nowhere near as big an improvement from std as any decent high or low mount would.
what about a low mount 6boost, obviously its not factory, but it would help to hide the turbo with some added heat shields and lots of stealth black.. Ive caved in and have ordered one to get every drop of response from the split pulse 3076, as the factory manifold has started to crack even after ceramic coating it before.
Edited by AngryRBGTX
How much better is side mount one than the factory one ?
Also wouldn't it be an instant defect if you got caught with a high mounted GT3076R ?
A .
It made 40kws more then standard Based on a ATR43SS2 turbo.
I'm getting over the whole street legal thing. It just comes down to how you can fool a cop, obviously smart cops can tell from those cover ups while stupid ones will defect you for having an "stock intercooler" or having wholes (obviously stock cooler piping) on the chassis .
Plus you can't go to EPA without a stock manifold, turbo, and exhaust. So get your self a good high mount ex gate setup, quite exhaust, and enjoy the power while you can. lol
  • Like 1
For Hypergear , does that Brae side mount manifold place the turbo pretty much where the Nissan cast one does if you spaced the turbo out for the T04S 0.70 comp housing ie GT3582R etc .
I also wonder if its possible to butcher a couple of std heat shields to come up with a bit of a "stealth plate" . Its not going to fool anyone who knows what they're looking at but would keep the daddy long legs a bit out of sight .
A .
A .
My side mount manifold was the very first one he's ever made. I had a deal in mind having them produced in quantity how ever the amount of time and parts required for this to work is far more involving then initially planed. It didn't work out.
Based on the manifold that I've received, bare in mind it was the very first one ever made. I score it 70% out of a 100.
Manifold does hold the turbocharger approximately on the same spot. which allows the factory dump pipe to be fitted as well as the water lines and drains.
The manifold pushed the turbocharger towards the chassis side by 25mms running that with an actuator and a standard actuator bracket becomes extremely difficult. How ever if external gate is used then that is no problems.
The bit I really didn't like was installation. Because it was all squashed together there are no room for tools. I had to remove factory rocket cover getting my spanners in, and skimm them so I can just turn the bolt. I don't think there are much can be done to this. But Once its installed its fine.
Performance wise it made more power then factory and any China manifold could ever reach based even running lower boost. How ever still fall 30kws behind his proper high mount with a 50mm gate.
Weighing up all factors, even tho it is a very good manifold, my vote still goes to his high mount with external gate.
what's with the crazy plate stack under the wg... cooling?
... is it just us Roy, but damn that looks cool!
I just machined out and re-welded my hks manifold. now I just need a motor to put it on :-) ... or it's going on the stagea.
Cheers
Justin
Legend01 (Pete) sold me on their merits years ago. He was doing his 2.3L when I was first doing my Greddy setup. I always preferred the HKS manifold for having a straighter exhaust flow / keeping heat away from the looms / easier to make good heat shields for / slightly more subtle / and the only cracks they seem to get is in the web of the split pulse flange.
With a black Turbosmart gate there is every chance that 90% of people wouldn't spot what is going on and the make engine bays look so clean.
Tone down the bling and it all looks pretty std
Justin
Good to see your getting it sorted! Hope it works well for you, was watching this thread ;)
  • 4 years later...
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
