i bought my gtt a while ago i have not known what exact injectors i have. i fitted a 3076r and type b cams, using a power fc. and when we went to tune i didnt no what injectors i have, but by already set numbers we assume they where 480cc, they were purple and said nismo on the side so we confirmed that. BUT. when researching the latency specs we cannot find anything at all. the injector on the side has a number 013 4608 we shows nothing when researching, now this car had work done at least 6 years ago including these injectors from what i know. Is it possible these are a old nismo injector that i cant find any information on. just need to know what this number represents, that there 480cc and what the latency times are. please help!!
thanks
Yeah he had some numbers but the car ran like shit when he set them in. Turns out he may have been right this whole time with the lag times because my maf is f**ked. So once I get the new one in it should all work out. Thanks anyway
I think what Jez meant by "The tuner will be able to work out the latency wen he is tuning" is that if the tuner knows what he is doing he will be able to work out what latency is correct by the way the car reponds when it is being tuned. What you do (with Nistune) is set the K value to give you the correct mixture when at moderately high loads (so that the latency is not significant) then, knowing that the K value is correct you go back to the light load/idle part of the map and fiddle the latency until you get the right mixtures there. Little details about setting the cells to zero and turning off O2 feedback have been left out of the above description. Whilst PowerFC and Nistune are not the same same, the process is similar.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
