Oem Wheel Colour
Docc
 Share
  • 4 weeks later...
Docc, i was told by Shipstones (QLD GTR Approved Repairer) that if i damage my rims they cannot match the colour of the rim in repair, they basically said if you damage the rim, its a new rim. Apparently its a 5 layer paint process with some different colours. I however did come across this entry on the GTROC site in the UK which talks about a Black Edition 2009 rim colour match, dont know if thats the same as your 2009.. Anyway here it is ? Hope it helps..
http://www.gtr.co.uk/forum/175970-wheel-refurb.html
yep my bodyshop made similar comment when i first brought my car in with the stock wheels
perhaps good excuse to go aftermarket, or maybe choose a custom wheel color (wheel solutions in richmond is the place to go) - if you don't stray too far from the oem gunmetal, you won't need to paint the inner barrels (which iirc are only based coated anyway)
Thanks sam.
  • 3 weeks later...
I touched one of mine up fairly badly a few years ago. Dropped it into Moorooka Nissan and they got it fixed for me for about $240. Can't tell the difference. Try your Nissan dealer. As for Shipstones pfft. I slipped while polishing the car one evening and put a tiny dent in the bonnet they wanted to remove, repair and respray ($2200). Found a good dent remover and he had it out in less than an hour for $150.
  • Like 1
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
