No, but I am often in this position myself seeing I chew through rear callipers myself for some odd reason.
I'd hit ebay (USA) and search for remanufactured 280zx series 2 callipers:
http://www.ebay.com.au/itm/AUTOCOM-PSC-Rebuilt-Unloaded-Brake-Caliper-REAR-LEFT-22-00516L-Nissan-280ZX-/251137842443?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a78fb5d0b&_uhb=1#ht_1468wt_1164
They should suit your needs.
i fitted hr31 Aarms to mine converts to inner drum handbrake and allows for easy fitment of r32 onward twin piston calipers. ventilated rotors standard.
if your interested ive got a couple pair of these arms spare complete with brakes and 4bolt shaft type hubs
jon.
Awesome. Thanks very much Drew. I didn't know that the 280zx series 2 calipers are the same. They certainly look the same. Are the piston diameters the same?
The needle rollers on the hand brake adjusting cam have disintegrated on mine.What have you been chewing through on yours?
Jeff
I have a box of rear callipers all in different states of disrepair and found there are a couple of different piston diameter sizes (to my surprise). For the life of me I don't know which calliper has come from which model car. Oddly they all seem to take the same shape brake pad, but according to the bendix website there are some subtle differences: 280zx brake pads have a small metal tab, whereas the R30 stuff is the same shape with no tab. What the tab does (if anything) is beyond me - as the pad with the tab seems to fit the big/small piston callipers anyway.
In short - it seems you can entirely mix and match calliper parts and pads except for the pistons/wheel cylinder kits.
I have no idea what's going on with my calliper's death with. After some time with them on the car there is a scraping sound, and when I grab hold of the calliper there is play in it. You can actually rattle the thing back and forth even though it's firmly bolted to the diff carrier - so maybe I am bending/damaging the two pistons the callipers slides back and forth on. I've replaced discs and pads (and cylinder kits) but still seem to eat the callipers at an unholy rate.
Hi Drew,
I checked out those calipers on ebay. They are the same piston dia as the DR30 at 42mm but they say that the centre to centre dimension of two sliding pins on the ones they have for the 280zx are approx 125mm. The ones off the Dr30 measure 110mm. What do the ones you have measure?
Cheers
Jeff
The busted calliper that I just pulled off the car measures 110mm - they probably came off an r30 hatch.
The set that I just chucked on the car are also stuffed, Ill measure when I remove them, but they are probably also 110mm.
Hey. I'm after some DR30 rear calipers too. Need them to finish my project! It's the last thing on the list. If anyone has a pair please get in touch. Definitely need DR30, not 300ZX/Z31, not R30, not 280ZX...
Cheers, Benny.
04 011 692 65
Thanks for all your answers but I ended up reconditioning my old calipers. I got the original pistons sleeved and got 280zx repair kits which fitted fine. The real problem are the needle roller bearings for the handbrake mechanism. I removed the stuffed needle rollers and made up bronze bushes to replace them. It all seems to work fine.
let us know how the bush goes. I was thinking of going down the same path. not sure over time it might start binding?
other option was i have some z31 rear brakes and was thinking of machining the back out of one and then pressing the bearing out to reuse.
Hey guys. Still looking. Looks like Tokico 5H are the ones I'm after.
I've found one but I can't find another. I'll pay good dollars to find another so it'll be worthwhile...
The one on the left with the flat bottom is the one I'm after.
Cheers.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
