as some of you may know i am going down the E85 road.
my question is the guys that are using it do you use your car everyday?
i have been speaking to to a few people and they have said if i am only using it on weeks ends it will causing me more problems as the fuel will drop to much octane over the week and will eat out my fuel lines?
they said to run fresh fuel everytime -
i will only be driving it the odd day during the week and same as some weekends.
what peopls experience / opinion.
https://www.sau.com.au/forums/topic/422362-e85-useeffects/
The people who you are speaking to have no idea.
I have run E85 for over 4 years, the car is lucky to be driven a dozen times a year. Before a drive the car is topped up with fresh fuel and away I go.
Sealed containers of fuel will last for months.
https://www.sau.com.au/forums/topic/422362-e85-useeffects/#findComment-6795246
That my thread and info is not in there hence this post -
NYTSKY - i dont mind having to top it up every now and then i guess i am more worried that it will eat through my fuel line and destroy them -
if i have to put new lot of fuel in every week i wont bother with it as i wont use a tank that quickly
https://www.sau.com.au/forums/topic/422362-e85-useeffects/#findComment-6795266
Nah man it shouldn't eat through your lines that would be if your probably left it for a long time without use,just have to empty the tank run 98 and leave it. The only thing that ive found is that you need to get supporting mods that can handle the alcohol content otherwise you shouldn't have any problems with the fuel line, that's probably the least of your problems. I'd be more worried about the consistency of your fuel because it could throw out your tune and depending on how aggressive the tune was it could go pop.
I don't think they meant that your octane will drop but they meant your mileage will drop, since E85 has a lower energy density meaning it burns more to produce the same as regular petrol.
http://www.injectordynamics.com/AlcoholArticle.html
Have read at this site might be worthwhile INJECTOR DYNAMICS wrote it.
They are still fixing the site so i cant dig up the thread its under Forced Induction
https://www.sau.com.au/forums/topic/422362-e85-useeffects/#findComment-6795520
thanks for that -
i think i am gonna look into the haltech elfex sensor, apparently its great to help your map adjust to different levels might look into that beofre i go into the e85 - with the mods i have my tuner said to put in a surge tank and 2 x 044 which i done so i guess everything else is ok - might have another chat with him before i decide
https://www.sau.com.au/forums/topic/422362-e85-useeffects/#findComment-6795930
  • 1 month later...
i have recently seen this walbro pump for e85... what about the normal pumps are they know to fail with e85? i am having the car tuned this thursday on e85 first time no one said anything about my intake pump (currently walbro 500hp in tank pump) pumping to surge tanl the bosh 044 to fuel rail.
what are you guys using as intanks..?
https://www.sau.com.au/forums/topic/422362-e85-useeffects/#findComment-6858531
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
