Hi All,
I am trying to find reference to a post here in the past for ECU fault codes but it seems to be gone. I just hooked up my laptop to the consult port (OBDII port) for a diagnostics run and sensor data logging to try and get an idea hopefully for a issue where my car intermittently and randomly blow some smoke. If my car could smoke a cigarette then its like it took a puff - lol.
Anyway I have fault code P0235 which I believe is turbo boost sensor? I recently bypassed the boost bleeder/controller as after recent mods with Criag's help my car was hitting 21psi. A little too high for kind of stock setup still. So I believe the code is for this sensor but I wanted to confirm incase is was for the other sensor that monitors boost pressure. I still have everything connected electronically. I just connected the inlet and outlet of the bleeder controller to each other (keep dust out), plugged the hole on the intake pipe and replaced the T with a stright through from inlet to waste gate actuator.
Any info on code 235 would eb great! Now to go for another test run for a speed trap test :woot:
thanks!
https://www.sau.com.au/forums/topic/422394-m35-vq25det-ecu-fault-codes-list/
If the boost goes above 22psi it will throw that code. You can trick the sensor into seeing less pressure with a small air pressure regulator as I have done, or perhaps simply blocking it will work?
Well cleared the error code and went for a boost. On return home no errors reported. So suspect the err 235 was indeed because of exceeding 21psi but that's fixed now. 17psi flat across rev range.
But now I got some hunting to do. I tried performing a Idle Air Volume Learn function and it will not complete. Was data logging my run so got something to analyse. Might have a boost leak somewhere or maybe not. Maybe idling too high or read maybe fuel trims are out (hope I logged that).
    • This could be sold and shipped to the US for many gold pieces. RMS has no say in that. Ask various Western Sydney inhabitants how it works.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
