Can anyone recommend a good rim cleaner?
I tried the non acid meguiars stuff cause its on special at super cheap, but it didnt clean anything, may as well brush my teeth with it. I might try the normal stuff they have if its still on special
Anyone got any recommendations? hopefully at a good price as im a tight bastard and im not a professional by any stretch of the term, so I just want something decent that does the job
https://www.sau.com.au/forums/topic/422404-wheelrim-cleaner/
Megiars non-acid is more gentle for polished, chrome or aluminium wheels, etc. "All Wheel Cleaner" has a bit more bite and is fine for painted factory wheels.
I've also tried Autoglym Clean Wheels (pretty good) and P21S Gel (very good but pricey). Megiars Wheel Brightener is probably the strongest one I have tried so far, but only comes in bulk trade packs and is a special order from most "walk in" auto shops
I use whatever is suitable for the job - usually the weakest possible cleaner, just to be safe. Also, the whole spray on/ hose off thing that some companies advertise is rubbish, unless you use a high pressure cleaner, elbow grease will still be required
glad i'm not the first person to say it.
was trying to clean my LMGT4s, used that cos it is 'gentle' but honestly i don't think it even would clean my hands...
I would also suggest to use a nice tar remover on the wheels as normal wheel cleaner wont touch it. Most wheels will have tar spots on them, especially on the inside barrel.
Once clean, seal them with a suitable product so they are easier to clean in the future. I just use normal carwash on mine now, after sealing them with Chemical Guys Wheel Guard
Bowden's Own Wheely Clean is awesome!
Non acid, destroys brake dust, a light agitation with a wheel brush, then hose off. Also comes in a 2L or 5L refill.
Job done.
http://www.bowdensown.com.au/wheely-clean
Hey Mate,
I have been using the AMMO range.
They have just released a new tire regimen and its fantastic.
I have some pics here of a 2006 Hilux.
I will try and get you some pics up soon.
Here is a video from Larry using the products
www.ammony.com
What are you wanting to clean - face , barrel or lip is it made of aluminium , steel
Is it polished lip , chrome face , painted lip and face , what finish do you have BE MORE SPECIFIC FFS .
I use Megauires Aluminium polishing cream with a polishing cone for lips
any spray on products do not clean heavy brake dust of at all and can damage paint
Best is use a sponge
Job done.
Yep another vote for the Wheely Clean from Bowdens, used them on my wheels after a track day recently and came up really well.
Hey Mate,
www.ammony.com
The Bowdens Own Wheely Clean works in exactly the same way as the AMMO wheel cleaner.
Is there anywhere in Aus that does AMMO products, or do you just buy online?
You're painting with a pretty broad brush saying "spray on products do not clean heavy brake dust" the one that I named, does exactly that!
Also I don't reckon washing wheels with a sponge is the way to go at all.
My wheels sometimes have little bits of tar or tiny bits of gravel stuck on them; if you wash the wheels with a sponge, the contaminants break away and get stuck on the sponge,
Then you end up with nice scratches on your polished or painted wheels.
Wheel brushes do a much better job.
Edited by Daleo
WHY ARE YOUR GETTING GRAVEL STUCK ON YOUR WHEELS . No wonder your wheels get scratched DERP
I have always used alight detergent. I keep my wheels clean so I never need to give them a good scrub. But when they are washed and dried I use Mr Sheen to finish them off. My rims have polished dish and this stuff does a great job. Plus it is awesome for windows too.
Spot on mate i agree , dont let your rims get so dirty that the brake dust bakes on hard from water and heat . Sprays are totally unnecessary .
I'm not sure; I've never taken the time to ask the gravel what it's doing there... :rolleyes:
Hot weather, poor quality NSW roads; the list goes on.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
