Hi guys,
I'm in the process of selling of my Z and reverting everything back to stock. I have for sale the only Motordyne exhaust currently in WA for a Nissan 350z. Not 100% sure if this will bolt straight onto a V35 but from my understanding, the V35's need extra piping which can probably be modified with any exhaust centre.
The Motordyne Shockwave is a true dual setup and is by far one of the best sounding exhaust notes I have heard for the VQ engines.
It is not obnoxiously loud when cruising but when you open her up there is a nice throaty exotic note (get a lot of compliments when driving around).
Here's a clip to give you an idea:
It has been used for about 40,000kms which has been driving to and from work. It is in relatively good condition but has a few scratches here and there.
I'm looking at $1300 firm at this stage and am able to ship interstate at buyers expense.
Pics will be uploaded shortly.
Update!
Pics:
post-39544-0-29350200-1364449544_thumb.jpg post-39544-0-93142100-1364449567_thumb.jpg post-39544-0-23797000-1364449584_thumb.jpg
post-39544-0-09002000-1364449600_thumb.jpg post-39544-0-48492300-1364449610_thumb.jpg
Will fit Nissan V35/350gt Coupes with a 8" adaptor. This can be bought from Motordyne directly:
http://www.motordyneengineering.com/product_info.php?products_id=83
Edited by sushiboi
I doubt you'll have a problem selling this at all, really sort after exhaust if i had the money i'd have bought Mitch's setup in Brisbane lol..
Pipes look great considering they've been on the car for that long.
GLWS
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
