decided to sell either my s13 or datsun 1600 which ever goes first.
so s13 rb26 n1 turbos its meant to have cams has a near new clutch and recently fitted a rb25 gearbox
gtr brakes ll round
gtr front seats
full cage
gtr diff and cradle even the key is gtr
has good handbrake set up
car is very solid goes well brakes well body is rough
i dont want people coming and saying its a bit rough as i am aware of it but its engineered and all there just needs paint also a wine in the diff has october rego
sms me for pics located at taree on the mid north coast
$11,000 ph 0412426573
you cant engineer these anymore so i am told.
or datsun 1600 fj20 turbo was told it was fully built but have no proof its not currently running due to computer upgrade which is
latest hatlech including race dash
full cage
r200 diff
2 speed powerglide
bigger turbo
external gate
engineered
harnesses
skyline disc brakes all round
this car has had a lot of money spent on it
very starght body.
no rego
$11,000 with no offers on this one.
0412426573 again pics by sms only
probably wouldnt bother replying on here or emailing me as i never check them
This is exactly what i've been looking for (except it's not in a S15 body) would you mind PMing me some pics? I could be keen. If you check here again that is.
  • 3 weeks later...
  • 3 weeks later...
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
