Exactly. And most of the stuff you want to do will most probably be done
lol yeah it's not as if people don't do the same farking mods anyway. Oh you went with -7s instead of -5s? You're an "individual"!
Save the "make it your own car" bullshit for aesthetics. Unless you're custom making mechanical parts, it's been done before.
If your going to mod anything at all on it, then go modded already. Let someone else take the financial hit. Just make sure you research the car as you should with either type and know what you're buying.
Modded doesn't have to mean 700kw, single turbo, HKS track suspension beast. (Although do want!)
There are some really well put together modded GTR's that would ride/drive similar to a stock car, but you usually have more power and in a lot of cases, better than stock parts.
It's a no brainer.
As per the above few opinions. I agree.
I drove lot of trackdays back in the day on including DECA's. The car was imported with all of the mods I wanted at the time. Drove it and changed a few things over the years.
In the end I never had to replace the engine, clutch, gearbox, diffs etc. All I upgraded was brakes, wheels and suspension in 7 years of owning it.
Why buy a stock car when for the same money or 5k-10k more you can buy a car with 20-40k worth of mods done to it. If you don't like certain parts sell them and buy what your after. It doesn't cost much to swap parts. It costs a lot to buy them outright!
Lots of you say standard cars are better but you end up with a weaker engine, turbos, clutch, diff etc than a modified car. I don't get your logic as all of your standard parts will break or need replacing due to power restrictions. So your going to be buying the parts anyway and spending money.
Why not just buy a complete wisely modified car and drive it instead of it always sitting in a workshop costing you money never being driven.
I know which I'd prefer....
Guessing like 99% of GTR owners you won't work on the car yourself so add this up.
Turbos installed $3000
PFC, AFM's and injectors $3000 inc tune
Forged pistons, oil pump etc $7000-$10000 installed
Twin or triple clutch upto$3000 installed
100mm FMIC $1000
Oil cooler $500-$1000
Exhaust $1000-$3000 with dumos
Wheels forged 18x10 with good tyres $3000plus
Brakes $2000-$5000
Suspension $2000-$5000
Gauges and boost controllers $1000plus
Plus all the other little bits and pieces.
All so you can have a car worth 5-10k more. Or the other options is as others have said. Keep all the standard parts and put it back to stock as I have done in the past to several cars. The owners were all warm and fuzzy thinking they bought a stock never modified car. The truth was....we all know the answer to that :)
I never buy toys so I can tell my mates about how cool it is and baby them around because I can't afford to have them break.
Oooo such an easy question to answer... if you plan to modify it, just go talk to any gtr owner - theyll tell you to buy a clean one that's already modified. You'll save a truckload of cash. I once read that you couldn't afford to own a GTR unless you could afford to buy 2. I've owned mine for 10 months, bought it with some clean mods and already spent another 20k on it which I'll never see again
yep very true i baught mine with all the supporting mods and still spend a sh*t load more lol its addictive :(
definitely modded over stock! If you dont like the mods on it its much cheaper to sell those parts and buy the ones you want than to buy them outright. A lot of very good points being made for modded so i think the choice should be very simple for you. Now stop being scared and go buy the baddest mo fo gtr you can!
LOL!!!!
Well, guess what, i bought a "stock" GTR. Stock as they said, but until you don't open the engine, you never know....
And it was a bit too late i read the comments about stock vs modded, but hey, thanks a lot for all your opinions!!!!
you guys are awesome in giving ideas/opinions :yes::no: LOL!
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
