Agree on the mini guns - they are pretty terrible for rate of fire; even at medium range.
Loving bf4 over bf3 though. I'm terrible at the flood map, need a shite load more practice.
I'm on ps4: floydwestwood98
Go on the roof above C and sniper. 90% of people don't look up there and you'll top the server.
Edited by RosieR34
Mini guns on the transport chopper?
Because if that's what you are talking about then I couldn't agree more. It's pretty much pointless using them.
Most of the time you would be better of hanging off the side of it with a sniper trying to shoot people
Yeah the transport chopper
I had a HORRIBLE night last night. No idea what my net was doing. Skill level went from like 220 to 150. K/D dropped from 1.3 to 1.06 or some shit. But my accuracy went up. So i had that going for me... Which is nice.
i went like 0/14 at one point. Surprised i didn't alt+f4.
Also can there be more f**king hardcore servers? i only play hardcore and there are f**k all around.
I only play HC - got a few good servers. MAD and EGL have some nice servers. Hit me up on origin, you too Dan.
name is Twistaz
My skill is only 160 and that's because I am the sheep when I play. I play with my brother and to say the least.. I am the healer/pilot in all aspects of the game. Which, tbh, I don't mind. But my stats get affected big time haha.
KD is 0.8 and skill is 160 - quite embarrassing...but I enjoy my role.
  • 1 month later...
  • 3 months later...
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
