Hello all,
My name is Chris, and I am from the US. I have trolled here for awhile, and figured I'd make an intro post finally. I am the proud owner of a '00 BNR34 (pics below) and a member of Skylineownersusa.com
I have a few cars:
'94 RX7: street tuned/built motor w/ 340 RWHP at 13.5 psi
'85 AE86 GT-V Levin: Had a full toda racing component built motor that detonated; waiting on new 20v to get in for a swap; TRD fiberglass hatch/fenders; slowly being turned into a full time track car:
original mileage(in kilometers =P):
00' GTR: car is currently under the knife. getting a BC 2.8L stroker with a Precision 6765 DBB
older:
newer:
Paint is Lamborghini Satin Pearl White
Edited by cLc
https://www.sau.com.au/forums/topic/422459-hello-from-the-us/
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
