  • Replies 50
If someone bids $80,001, they will be leading the auction
AFAIK, any valid eBay bid is a legal contract, so unless someone outbid it, he is legally bound to sell it for that amount
Bargain really
dunno, but either way its a legal contract, I am sure its been thought of before he posted it. I'm sure ebay would be licking there lips, as they take a decent percentage :D
It would only be $40.00, after the initial listing fee of $5.00. But regardless, there are plenty of outs for eBay sellers.
Can anyone confirm that this car really has an N1 Block & HKS 2.8 Stroker Kit? Cause I have heard otherwise, and that it may have wiseco 87.5 forgies, tomei Poncams ~260's with a 9.1lft but is nowhere near 2.8ltr?? And the add says it does have a HKS 2.8 kit & N1 Block? And I've also heard the car has had troubles with blowing turbo gaskets.. why would this happen?
all sorts of stories are floating around about this car........
I believe it may also be a time machine, simialr to that of Delorean from Back To The Future.......:bahaha:
Best let the owner answer your questions, as its his car, and there are alot of differant specs being posted around the place . I am sure he created the eBay advert, but he also has said it runs 9's, later admitting he said this to add attention to the sale....
either way, nice ride and worth every bit of 100+ grand IMHO
Chris
Bargain really
if reserve price is not met there isn't any contract
I wonder what the reserve price is?
Apparently this car was seen on the back of a trailer heading over the west gate bridge into Melbourne yesterday. Wonder if its sold already? Still had the COPYME plates on it however.
Yeh it's been sold to Grn tourismo... It was supposed to be heading to ICE this morning :D poor Gerald I made him wake up early, he was going to check it out for me. Fate has it's ways & probably for the best. The car is definatley not what the ad says it is.
Sold to GTA? Thats funny - I popped in there last Sat to see some of the new arrival GTR's and all they have is the old beat-up R34's that have been for sale for ages floating around. That means that they will now have 5 bloody R34 GTR's for sale! LOL.
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
