Les Lothringer's Approach to Removing Rear Seat in R32 GTR & GTSt, without damaging Retainer or Seat.
May be applicable to similar Skyline models.
- Duration: One minute one person to remove.
- Difficulty Level: Easy once you know.
- Special Tools: Bent Flatblade Screwdriver to release the Seat Retainers - 2 of.
- Other Tools: Large pliers, gas flame, possibly hammer & anvil. Background music of your choice.
- Parts: None.
- What Can Go Wrong: Hard to go wrong but you never know. Using a short crowbar to lever up the seat will damage the retainer and the seat; may possibly bend the floorpan.
- Reference: None used.
- Note Disclaimer below.
Approach:
1. To make a Right Angled Screwdriver Head, take one Flatblade Screwdriver, 5 mm wide blade, heat over gas flame to red heat, use pliers or hammer & anvil to bend 90 degrees, 15 mm from centreline of screwdriver. Quench in cold water - see Pix #1.
2. Refer Pix #1.1, #2 & #3. To release Seat Hook, place screwdriver between the Seat Hook, inside Retainer. Lift screwdriver handle to open up Seat Retainer while lifting seat. Perform both sides to remove bottom seat.
3. Removal of rear seat back is self-evident.
4. Fitment is by sliding seat Hooks into Retainers.
_________________________________
- Les Lothringer's Disclaimer [short Form]: This describes my approach. If you choose to follow it and make a mistake, remember - at all times, it really is your fault, your risk and your cost. If you choose to follow it and get a different outcome, that's because you need to know more than what is described here. If you choose to follow it and something subsequently and in the rich fullness of time goes awry, you bear the consequences, deservedly or otherwise but probably deservedly. Recognize that your car may have been worked on by a previous owner who knew less than you do [scarey!!], who may not have applied good workshop practice or whom may have been a qualified workshop technician operating to unrealistic "industry standard job time" pressures and so took yet to be revealed shortcuts with unfortunate or even dire consequences or perhaps prepared the car for sale under instructions from a previous owner to "keep it cheap mate". If you lack the confidence, ability, manual dexterity, clear eyesight, intelligence, mental clarity, patience, emotional stability, knowledge, focus, correct tools, time and a firm, level under-cover location free of rain, flood, high winds, blizzards, sand storms, ground instabilities, ionizing radiation, blood sucking insects, inadequate lighting, excessive noise, distractions of any kind, subterranean volcanic activity, very low flying aircraft, terrorist actions, foreign invasion, etc etc etc, or otherwise believe in the power of prayer to keep you from screwing up in the performance of these tasks or even worse, possess a wife [or wives] or partner [or partners] pestering you to complete the work in what seems to her [them] to be more than a very reasonable affluxion of time, engage someone who does not. No responsibility accepted for srorre, omissions, misguided and unjustified assertions. Every car can be different. Your car may have design defects courtesy of the manufacturer [probably does] or aftermarket manufactured parts applied [quite possibly and made to another engineer's standards or maybe a committee of engineers with the usual interference from cost accountants (I did cost accounting)] or outstanding campaigns issued against it, as yet unapplied or applied incorrectly or components designed / manufactured under no intention of being serviceable [built-in obsolescence].
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
