evrybody out there that has lost all there point know that feeling in the gut when you know your out for a month or more cause of some excessive speeding.
got the fine in the mail today. *** no dramas take it on the chin.
(this one is for felafel, cause i know this is going to shit ya)
though i was out for a month cause i only had a few points left and the fine make 0.... right wrong
did some ringging around casue my car is registered and insured under my company...... you only have to pay the fine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thats correct only the fine
no points lost
no nothing
"*** yea whatch me dance its your birthday"
this is like a tax loophole if you dont exploit it you r a tool!!!!!"
pete
https://www.sau.com.au/forums/topic/4225-out-of-pointsfelafel-youll-like-this/
Used to work for a private company in Victoria, where the guy that owned the company had a lot of company cars, Porsches, a Ferrari Boxer, stuff like that. He got booked by a speed camera doing around three times the speed limit in the Ferrari. When he got the fine through the mail he told them it was a company car, and that he could not say for sure who was actually driving it at the time (it was him obviously). They said no worries mate, just pay the fine, and hand in the plates for twelve months. He did not care, lost no points, and had other transport. This might not work for everyone though.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
