  • Replies 70
Not sure your weight figure is correct.
An ARX is 1780kg and an RX is 1680kg.
But if you want to lighten it have a look at changing Electric front seats or removing some of the electronics.
There are not many other places to loose weight as the subframe and suspension are all alloy, bonnet is alloy, boot is plastic composite.
On the upside, all that weight is near perfectly balanced on the chasis with 52% on the front axle and 48% on the rear.
Enjoy.
Nope, RX is awd, as is the RS.
Mine weighed in at 1670kg on the weighbridge at my work.
Considering a stock VE sedan is 1700kg, and even a fully loaded FPV ute is over 1800kg; I don't think there's much to worry about.
I know what I'd rather be driving in an accident.
Or any other time for that matter...
RS if you have triple gauges in the centre, RX if you don't. I think that is a safe measure, unless installed later, right guys?
Or plug in your VIN into something like epc data for the run down.
180sx: 1150kg and three times as powerful as your car.
You Jelly?
^ Yes, yes I am.
I put mine (RS) on the local weighbridge & it came in at 1800kg with me in it, after I had removed all the ususal suspects (spare wheel, tools, sub, mats etc.). All the lux adds weight, no doubt.
I'm not concerned though. This article on the weight of the R35 GTR gives me some peace. http://www.topgear.com/uk/photos/kazutoshi-mizuno-nissan-gtr-interview-top-gear-2012-02-23?imageNo=1
With the right tyres, our cars handle better in torrential rain than most do in the dry.
Your in a wagon who cares for weight loss. Rip out your high flow vq and send it to me. That should save you a good 300 kg, take off your wheels and stick it up on blocks that will save you 100kg give or take. Take out your r35 gtr seats, bc's and swaybars and that should save another 50kg .So that will make you about 250 kg heavier than the 180 but you wont be moving far....
I care for weight loss funny man. That's why I started the thread.
But all you're going to end up with is a noisier, harsher, less pleasant car to drive.
And it might accelerate a poofteenth quicker, or save a bees dick of fuel?
If weight saving was your primary concern; why on earth did you buy a Stagea?
If you do anything to your car that displeases me; I may have to kill you.
Lol, jokes. :whistling:
But seriously; don't. ;)
Edited by Daleo
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
