it ain't glamorous and it ain't fun... but when you do it regularly magical things start happening... an awesome exercise if your feeling stressed or frustrated... a proper squat session is like nothing else, it gives you an awesome appetite and you sleep like a baby
and it cures cancer... obviously
my old man is nearly 70, 65kg and does 5 sets of 20 reps with 60kg... don't let a senior citizen out squat you!
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6802596
I was watching the fattest losers last night while eating a bowl of ice cream with cookies and maple syrup... and before it came back from an ad break, the commando was on giving a "TIP".
I cheered and did fist pumps like I had just won lotto..
There was the commando, Barbell on his traps.
And it goes something like this.
C - "Here is an exercise that will not only help you lose weight but also give you an all body workout and get you strong" Squats!
me - "here we go.. time to see some 1/4 squats to make sure the knees are safe"
C - "If you want, start with a broom stick to get used to the position... what you want to do is put the bar across the back of your shoulders, pull your shoulders back to create a platform there, have your feet shoulder width apart, take a breath in, then sink down and back keeping your knees out until you are at the bottom (he was well below parallel), then push back up. Everything moves up together, everything stays tight"
me - "Holy shit!!"
C - "get some weight on to the bar and start by doing 3 sets of 10 reps then increase the resistance. If you are over 40, you may need to be more careful of your joints.. I recommend *insert some brand of joint formula here*" (pumps out nice full depth reps as it fades off to an ad with the other male trainer and same joint care formula)
me - *choking on a cookie I didn't fully chew* "f**k yeah!! - Do some squats you fatties.. get that up ya!!!!"
Didn't even care that it was an ad for some shit.
Edited by TTT
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6802670
inb4 Birds' squat thread
Currently:
60kg x 10
70kg x 10
80kg x 10
90kg x 5
60kg x 10
70kg x 10
80kg x 10
90kg x 5
95kg x 2
Watch this space for big improvements, given I can only work legs at the moment. May start dropping to 5 rep sets, as my warmups are taxing me up top quite a bit...though its not as it I'm not making gains.
The ATG squat has a bias towards glutes and adductors, so I'm smashing leg press after squats to give the quads a good bashing too. After this and hamstring curls, I start walking like a zombie.
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6814200
if you want more quad work try front squats with an olympic stance
you could squat twice a week... do one day with high reps, light weight... sets of 10-20... then do a heavy day where you do very light warm ups then do 5 x 5 or even 5 x 3
in the above your mixing both... which as you say makes you too tired when it gets heavy
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6814228
Or I could squat 4 times a week, 2 for light weights and 2 for heavy :D
Good suggestion though. Might allow my legs to recover quicker too.
Can't really do front stance, as I think it will aggravate my supraspinatus. I'm lucky that i can bend my arms enough for high bar. My quads do get plenty of work, don't get me wrong...but it's nice to add that little extra with the leg press and to finish them off in a way that squats can't without losing form. I was considering mixing up the parallels with ATG so that I get a bit more quad action going on there and have more strength for getting out of a half way hole.
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6814288
60kg x 10
70kg x 10
80kg x 10
90kg x 5
95kg x 2
60kg x 10
70kg x 10
80kg x 10
90kg x 6
95kg x 3
Might add a 6th/1RM set to this so I can start using it to leverage my sets of reps and up their weight. 100 should be fairly doable for a start.
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6818205
    • did you go to the us gtr festival? any progress on getting the car back out and running?
    • I had some time over the last week  and decided to test if block filler will hold the blocks shape similar to a torque plate after the head has been removed. 1, 3 and 5 were measured at 9 points each before and after. MY goal was to see how much impact a torque plate has on the shape of the bore. The first set of measurements were taken with the main girdle and head off with no filler. The block was then filled with grout up to the water pump (half fill) and the girdle and head were torqued to spec. The block sat leveled for 7 days and was disassembled. The second set of measurements were then taken. Results are presented as the delta between the original and new value. All values in the PowerPoint are presented in inches because America. The largest changes were 0.0035 in or 0.0889 mm between cylinders 3 and 5. There may have been even greater changes if the block was filled to the top with grout. I hope this information is useful and I'm curious to hear what you guys think.       Notes: My block had the most wear in cylinders 3 and 4. Due to the amount of change in 3, I measured 2, 4 and 6 separately. 4 was also all over the place. 6 was similar to 1. They were not included to keep the test objective.
    • I also find it hilarious, everyone thinks chop idle tunes sound cool, and they do... Because they sound like an angry rotary engine idling.
