Have you tried stretching or using a really light weight at the end of your sets to try and push lower? I've always had good hip flexibility despite my long legs. My hamstrings are pretty poor though.
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842246
Next session go
bar x 10
40 x 8
60 x 5
80 x 3
100 x 1
then go 115 and 120
stop doing a million reps before your 1rms
Why you gotta hate on my gazillion reps? I love the volume stuff.
I know that's the best thing to do to increase 1RM, i.e. cut down on my volume...so I'll probably turn to it when I start plateauing bad with the current setup. But for now I enjoy sticking the 1RM after a heap of working sets. Because Birds
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842252
Argh
http://answers.yahoo.com/question/index?qid=20100122075103AABalxd
Came across that when tryin to find that bad technique thing where the ass "rolls" or "dips" during a squat. What's it called again?
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842501
Cheers
Yeah I gave up reading after the first two comments. The chosen answer supposedly a trainer for an international weightlifting association? Err...
There's misinformation and then there's MISSINGinformation!
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842620
do your volume after you go heavy, not before... just do enough to warm up, hit a pb, then do a heap of volume work
^^ This.
You're not going to find your 1rm doing it your way.
You're only going to find your exhausted 1rm.
Do it like I said, then once you fail a 1rm, have a 5 minute rest, then load up your volume sets and go for broke back mountain
  • Like 1
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842960
60kg x 10
75kg x 10
90kg x 8
100kg x 3
110kg x 1
Got a bit worried on the 90, being down a rep from Friday. Felt good about the 100 x 3 though, so I shot for 110kg and there it is. Will try and get 2 of them next time or shoot for 115.
60kg x 10
75kg x 10
90kg x 8
100kg x 3 (died half way up on 4th rep)
115kg x 0 (died half way up)
Didn't make the 115 tonight; back just didn't want to work with me after the fail on the 100s. Next time maybe!
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6846202
  • 1 month later...
60kg x 10
75kg x 10
90kg x 8
60kg x 10
80kg x 10
100kg x 4 (fail on 5th rep)
110kg x 0
90kg x 3
Was sick with a cold this week, debating whether to come. No one ever got anywhere by being home with a cold, so here I am.
Feel like I'm leaning forward too far on the heavier weights and the motion is turning into a bit of a good morning, as my back is giving way before my legs are. Seems to be consequential of trying to squat all the way to my ankles in oly stance; need to sit back on my heels more and keep the hips from coming up before my back. Hoping to post better results next sesh.
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6898825
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
