As long as you have safety bars in place at the right height, you're not going to break your neck. The body tips over forward and you end up on your knees with the safety bars taking the load, before this happens.
If you feel like this, you need to tilt the head up higher, chest out further and shoulders back further.
yeah I used to get that a bit until I started really using my rear end to power up, and stopped wearing heeled shoes
I wear powerlifting shoes, so maybe I need to focus on using my rear to power up as you say if I start squatting again.
If you are tipping forward when coming up, it means that your hip/rear is already rising faster than you can handle.
you either lack upper back strength or need to practice squatting more upright.
Front squats are good for this.
I tried to do front squats as I cant back squat due to my injury but I couldn't even front squat the bar. Can't seem to get any upper body strength going on.
Sorry I didn't know you had an injury.
Why couldn't you squat just the bar? too heavy or injury related? mobility?
yeah too heavy, I just couldn't get the mechanics of balancing the bar in front of me.. yet I was back squatting 65kg
You should easily be able to front squat the bar. Keep your head and elbows high.
Just try bw with a broomstick til you get comfortable doing it
Edit: TTT suggested broomstick as well, great minds think a like
Crossed arms sucks, I prefer the other way
Edited by Mitcho_7
Yeah tipping forward. Birds would be able to explain it better than me
Only seen you attempt it once and I forget where the point of failure was.
I'm not very good at front squats myself...arms don't quite have the flexibility for it yet.
I actually find front squat positioning/mechanics much easier to get good depth but obviously cant do as much weight.
Keeping your elbows high and head up are really the only cues I use. As soon as the elbows drop its about 20x harder I find
Edited by Mitcho_7
my injury is between L5 and S1 so even though I wear a belt it, I can't get it low enough to support that area. It's right down at the top of my glutes.
what TTT said about falling forward is really good advice. It took me a long time to learn how to sit back into a squat and use my glutes instead of shifting my weight forward and using my quads.
I was a lot stronger squatting from my quads in the beginning. Any time I felt the weight get heavy I was shifting weight onto my toes. Wasn't helped by the oly shoes I was wearing. This was until I started having crippling knee pain. Its was so bad I was hobbling around and couldn't sit for long periods without them aching.
So I ditched the oly shoes and practiced sitting back, having the weight on my heels. I would actually lift my toes off the floor as I squatted to make sure I didn't come forward. Later I also switched to a low bar position which also helped and I do a lot of front squatting as assistance. Very difficult to not sit back when front squatting as TTT suggests.
This fixed my knee pain but makes it really hard to buy pants/shorts as my ass is heaps bigger! lol
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
