As long as you have safety bars in place at the right height, you're not going to break your neck. The body tips over forward and you end up on your knees with the safety bars taking the load, before this happens.
If you feel like this, you need to tilt the head up higher, chest out further and shoulders back further.
yeah I used to get that a bit until I started really using my rear end to power up, and stopped wearing heeled shoes
I wear powerlifting shoes, so maybe I need to focus on using my rear to power up as you say if I start squatting again.
If you are tipping forward when coming up, it means that your hip/rear is already rising faster than you can handle.
you either lack upper back strength or need to practice squatting more upright.
Front squats are good for this.
I tried to do front squats as I cant back squat due to my injury but I couldn't even front squat the bar. Can't seem to get any upper body strength going on.
Sorry I didn't know you had an injury.
Why couldn't you squat just the bar? too heavy or injury related? mobility?
yeah too heavy, I just couldn't get the mechanics of balancing the bar in front of me.. yet I was back squatting 65kg
You should easily be able to front squat the bar. Keep your head and elbows high.
Just try bw with a broomstick til you get comfortable doing it
Edit: TTT suggested broomstick as well, great minds think a like
Crossed arms sucks, I prefer the other way
Edited by Mitcho_7
Yeah tipping forward. Birds would be able to explain it better than me
Only seen you attempt it once and I forget where the point of failure was.
I'm not very good at front squats myself...arms don't quite have the flexibility for it yet.
I actually find front squat positioning/mechanics much easier to get good depth but obviously cant do as much weight.
Keeping your elbows high and head up are really the only cues I use. As soon as the elbows drop its about 20x harder I find
Edited by Mitcho_7
my injury is between L5 and S1 so even though I wear a belt it, I can't get it low enough to support that area. It's right down at the top of my glutes.
what TTT said about falling forward is really good advice. It took me a long time to learn how to sit back into a squat and use my glutes instead of shifting my weight forward and using my quads.
I was a lot stronger squatting from my quads in the beginning. Any time I felt the weight get heavy I was shifting weight onto my toes. Wasn't helped by the oly shoes I was wearing. This was until I started having crippling knee pain. Its was so bad I was hobbling around and couldn't sit for long periods without them aching.
So I ditched the oly shoes and practiced sitting back, having the weight on my heels. I would actually lift my toes off the floor as I squatted to make sure I didn't come forward. Later I also switched to a low bar position which also helped and I do a lot of front squatting as assistance. Very difficult to not sit back when front squatting as TTT suggests.
This fixed my knee pain but makes it really hard to buy pants/shorts as my ass is heaps bigger! lol
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
