Squattin
TTT
 Share
  • 1 month later...
Coach T's voice. Man his accent freaks me out a little.. lol. Damn French Canadians. T-nation used to be so good for reading info... Now they just plug their products in just about everything.
Front squats are boss. I found my rowing strength increased once I included these, upper traps got a good stimulus too!
How are your numbers going Nick? I was just reading through the thread and a lot of the fella's in here have some good looking numbers. I'm assuming most of you train for PL comps?
The importance of leg day became most apparent to me during basketball lastnight.
Opposition were all gym brahs, at least 90-95kg a pop and mostly lean...I'm still my sleight/tall 77kg and NONE of these guys could move me out of the way in defense; they simply bounced off me and in offense I was able to hip push them out of the way to take boards. There's a reason a tree trunk is thicker to the ground...
All in the roots, brah
Edited by L33SH
  • 1 month later...
  • 2 months later...
Easy!
My squats are pretty average since I had 3 weeks off. I'm only 2.5kg off my pb but I've lost my endurance. I was doing 60kg x 13 now I'm doing 60kg x 5 and that's a struggle. Luckily I'm making pbs in bench and deads to make up for it lol
Very strong squats mate what bodyweight you at?
I take it you are lifting for power not bodybuilding? Maybe not.. I rotate power sets and high rep sets. Firm believer in being strong as well as lifting to look good
I'm an easy 86kg@179cm, not lean, not big enough.
I've put on 10kg weight (probabaly 50% functional/muscle) and 50-60kg to my squat 1rm in last 12months.
Legs are where a lot of the muscle has gone. Stick legs, gone up 2-3 pant sizes.
I've always done a powerbuilding type split, I do Squats,Bench,Deads,Military as a strength exercise using powerlifting cycle templates., accessories are more hypertrophy.
Good stuff very solid at that weight. I have always found legs the hardest things to build but one of the most important. After many years of training its only the last 8 months that i have made ANY ground on them. I never used to squat which was half my problem but injuries from football prevented that. Now fixed my self up and squat 150 for 10 reps but i only go just before parallel. My bodybulding training has me doing slightly less weight with a lot more reps with long pauses at the bottom and this has made them grow. put on 2" in 8 months so happy with that.
My training partners legs are ridiculous and cant wear jeans or anything like that. I dont want to be the tailored pants dude hahah
With the 5x5 you will get 200 easy! good luck
I have a friend that is a tailored pants kind of guy.
I don't use 5x5, but I'll get there just the same!
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
